Hi All,
I have just purchased and set up my China CNC 6040. Although Mach3 reports the X, Y and Z data is changing, none of the motors move. They are all correctly locked up when the power is turned on. I have tried a couple of old XP based PC's with standard parallel/printer ports so I think I am transmitting the data OK. I took the case off and can only assume that the yoocnc-450JKB (breakout) board has failed. Is there a simple way to test the output of my parallel/printer ports and generate test inputs to the 450JKB to check the motors move?
Cheers
Gary
