Ok, some reporting back here. As I now had some time to play with this thing again.
One thing people who also buy this thing (my "exact model"
is the CNC 6040 by "CNCEST" as sold by chinese ebay sellers, that name is on a sticker on the device) -
the longest (Y) axis' ballscrew is wobbling around.
I have not read about this as a problem anywhere else, where people mention the "by design" shortcomings of these chinese CNC routers, so probably "my" manufacturer just screwed this one up.
To demonstrate:
Running - note the motor coupling to the right:
Stopping after some steps, so you can better see how the distance between ballscrew and the steel angle thingy changes, depending on rotation angle of the motor:
Here my crude attemt at measuring the deviation, roughly 35/100 mm total, at the edge of the coupling anyway:
Looking at the ballscrew itself, it looks like a lot more than just 0.35mm, though.
So this will probably break the bearings if I use it that way, I wonder how they managed to get it that bad.
The frame of the whole thing seems relatively sturdy as such. Then again, the gantry and all the stuff on it are pretty heavy. Maybe I was less lucky than others when moving the whole thing around on the desk, and the whole setup warped somewhere?
Or they just screwed up, tired at end of working day or so
Now, I am currently struggling with the ebay seller to make him understand the problem, and he's playing dumb, of course
He already did that when I showed him a photo of the ingenious re-design of his water pump - the brass connector piece for the output hose was solid, i.e. no hole for water to come through, and never mind the broken off pieces of plastic from the side of the pump - I guess more water comes in, as compensation for the "tight" output!
I reminded him that paypal protection is still on for a number of weeks, suggesting he makes better suggestions than so far.
Let's see how that turns out...
From what I gathered by a post in another forum about the proper setup procedure for such a ballscrew and bearings, it sounds like I could never possibly do such a thing myself, as bulky, complicated, expensive precision parts are required.
So the only real option is that I send the base with the Y-axis parts back for repair, eh? (apart from returning the whole thing).
