Author Topic: Crimp pins for SCART cables?  (Read 1569 times)
Offline krivxTopic starter
  • Country: ie
« on: July 09, 2014, 01:55:26 am »
I need to modify a couple of cables with SCART connectors. Most of seem to use crimp pins which I would like to use, but I can't seem to find a source or even a name for the type of pin used. The actual pin is a vertical blade type and not the usual round or square contact. Datasheets for connectors don't seem to specify the pins, as they are usual supplied with a set. I don't want to have to buy different connectors just to see if the included pins will work for me. Does anyone have any ideas?
