Author Topic: Damaged Tronex side cutters  (Read 2336 times)
Offline malchTopic starter
« on: June 20, 2014, 03:58:38 pm »
I bought a Tronex 7082 side cutters.
These are Razor Flush with a set screw to set the cutter gap.
I took them out of the box and zip-lock bag . I tried them on a small wire. I screwed them up.
The cutters came with the set screw turned out [not adjusted] , so the edges scrunched each other.
Also the set screw [3-48 x 1/8] was only holding on with one thread when adjusted. I bought ten  3-48 X 3/16" set screws to do it right.
There should be a note in the box warning you to adjust the set screw before using.
Toying with the idea of sending them back to Tronex for resharpening.
« Last Edit: September 29, 2014, 08:43:06 pm by malch »
Offline nanofrog
Re: Damaged side cutters
« Reply #1 on: June 20, 2014, 10:02:01 pm »
The screw should have been set at the factory, so I'd contact them first before paying them a resharpening fee (request a new pair rather than resharpen).
FWIW, I have the same pair, and the screw was set (same with Swanstrom's I have that uses a setscrew). So I suspect you got one that managed to slip through QC.
