Since 2 years I have a MFR-1351 with soldering and desoldering handpiece. I use it professional. Within a year the desoldergun died and the soldering handpiece strainreleave broke (that was after a week or so)
Farnell gave me a new station under warrantie.
A few months ago I noticed the wire from the replaced soldering handpiece was warm. But that got worse. Last time I used it (a few weeks ago) I burned my arm. The wire temperature just outside the handpiece was over 100 degrees Celcius (the temp water boils for the imperialists ;-) )
Farnell told me the warrantie is 2 years, the first year via Farnell, the second via Metcal direct
But Metcal USA reacted a bit bizar:
- First, it was a known problem solved in the handpieces sold now. But they wanted the number on the connector. I mailed that and I had good hope
- The answer, Sorry, warranty is only one year and yours is older
- They adviced to buy a new handpiece.
It is not the money but the fact that they know their gear is dangerous and do nothing. I bet that if I was in the USA this would end in court and would cost them much more as 70 euro for a new iron... to bad I live in the Netherlands.
Does someone know what is going wrong in the iron and if there is a risc my desolder handpiece will get the same problem ?
In the mean time I gave my trusty old MBT250 a good overhaul (i had kept that as a backup but over 20 years old I wanted something new and faster heating so bought Metcal
) , replaced my crusty SX-70 for a brand new SX-100 (wow, that sucks, in the right way
) and now use that set as main soldering station (I also have a 10 year old Wellerstation I use for smd) The Metcal had more issues in 2 year as all my other soldering gear over > 10 years.
