Hi everyone,
I have just bought a Dataman-40Pro eprom programmer and I'm having some problems with it.
The first time I connected the programmer, everything went fine. When I disconnected it, I felt an electric shock (I was touching the case of the computer and the USB cable coming from the programmer). The second time I connected the programmer, it was dead, not recognized by Windows (USB device unknown) !
Upon further investigation, I discovered that the negative side of the power supply is floating at 85V AC above earth potential!
I measured a 85v AC potential between the ground of the usb cable coming from the Dataman and the case or usb ground on the computer side.
I ordered a second unit and the symptoms are exactly the same !
Dataman support basically told me "that's ok, it's how floating PSU work"... but I'm clearly not satisfied with this answer.
What do you think, is it defective ?
If that really is "how it's supposed to work", what can a do to prevent it to break again?
Thanks in advance !
CRi
