- What does it take/is if feasible to mill fine SMD footprints like a 0.5mm pitch TQFP100 on a CNC mill?
To mill SMD footprints with an extreamly small pitch, you need very high RPMs
to use a very small, we call it "Stichel", it's a mill cutter primary for engraving
with only one sharp 15 degree V-shaped tooth.
For this small cutters you normaly use a inverter driven high speed spindle
with up to 25000RPM and more.
- I notice the machine I am looking at has a max spindle speed of 8000RPM, would higher speeds be of much utility for PCBs?
Definitely yes!
The smaller the drill diameter the higher the needed RPM,
same for the trace spacing with the Stichel.
- or will I constantly have to tweak the mechanicals to make it preform satisfactorily?
I never ever saw a chinese (except taiwanese) tool or machine, within the machine building
segment, that worked satisfactorily ex works without the need of massive tweaking and rework
For PCBs with "normal parts" this mill could work for hobby purposes,
but for SMD parts with small footprints like TQFP100, I am not sure.
