For the SMD soldering practice, I already noticed that few challenges will come with my eyeglasses (and the current status of non-perfect vision). The ones I own near distance work (+3) do currently work best under 1m distance. The best sharpness is on the lower section on glasses (for distances less than 0.3m). It is not enough to move my eye, also need to turn head. For the long term solution with SMD solder practise / SMD stuff - I do need to get some solution for the home use also (in parallel to that, I will teste the stereo microscope at local ham radio club).
For the magnifying work light (with adjustable arm), many of those have traditional big glass (or plastic) lens. I do not have here one to test - so I ask do they offer sharp wiew overall the lens area or is it needed to put the point where you work on SMD - to the center of your magnifying lens ?
Also, is there any similar work light offered in fresnel lens ? Just wondering if that type of lens offer better views on wider area ? I can see with google, that there is some desktop stands (with a fresnel lens) what you put on table. And there is some space below that - I am not fully sure if that is very usable on PCB soldering, ie does the PCB plus solder tools fit properly under that?
One solution might be to check if suitable headband magnifying lenses exist...
