...[snip]...I'm not much good with using the manual one.
What have you used?
Seriously, they're not all the same. I've used the inexpensive models, Edsyn, and an Engineer. The Edsyn works well, though the original is a bit large (Soldapult
DS017). They offer more than one model though, and they vary in size. These are such you flip it over and push the plunger down on the bench top for one handed operation.
The Engineer (
SS-02) is a lot smaller, which makes it easier to operate with a single hand IME. It also uses a small bit of silicone rubber hose on the end, which does a better job of making a seal vs. the inflexible tip on other types as it's typically held at an angle so you can get the iron on the joint. It allows you to keep the iron on the pad when you push the plunger release vs. perfecting the technique of using an inflexible tip (pull the iron, get the tip perpendicular to the pad, then hit the release button in under 1 second or so).
If the suction is good, you could add a bit of silicone tubing to improve the seal. And it can be had on eBay really inexpensively, so you may be able to improve yours without buying a new tool (say
4mm ID should do for the nylon tips IMHO). Worth a shot IMHO at any rate.
They are cheap, so maybe it is worth to have some, just in case. Especially parts with only a few pins can usually be removed rather easy.
I agree.
Manual types certainly work, but can be a PITA. And the cost of a desoldering station makes these very attractive. Heck, even if you toss them every 50 joints or so (
$1.46 shipped from China), they're just a consumable like good quality desolder wick (which is still necessary of course).
