In my small experience on the analogue side, it is a compromise between reaction times and unwanted oscillations. The point at which oscillations will occur depends on the whole topology and even the parts used from beginning to end, anything inside and outside of the control loop can and will affect the circuit, and there will be weird situations that you cannot possibly predict or test.
For example I thought I had a fairly stable two channel PSU, with both channels the same identical PCB and parts (well within reason), and when powering a remote device pulling around 2A on each channel at 12V and 200KHz, thereby having 25+ volts dropped on the pass transistors, one of the two channels started oscillating in unison with the current drawn while its identical sibling did not. The oscillations occurred because I had removed 1000uF bypass caps on the target device, and went away when I put them back in, but of course you could try to power a device that has absolutely no bypass caps, no low pass filters (chokes and caps) at the power inputs and will leak all sorts of noise around everything else. So I do not think there is a universal solution.
