It looks a bit like someone has added some black varnish or something and printed the RB205/MCP418 on top (based on the shiny appearance of the top compared to the bottom), either just to give it an in-house part number for some end application or because it is custom programmed. I wonder if you could very carefully remove it somehow (suspect sanding would ruin any marking underneath) and see if anything is printed/laser marked underneath.
