Author Topic: ENGINEER SS-02 SOLDER SUCKER review + awful service customer  (Read 22629 times)
Offline technogeeky
  • Older New "New Player" Player Playa'
Re: ENGINEER SS-02 SOLDER SUCKER review + awful service customer
« Reply #25 on: December 05, 2016, 10:22:07 am »
FYI, and for search references:
This appears to be the same part as the "famous" Adafruit solder sucker (part number 1597, link here). They sell this as Professional Silicone Tip Solder Sucker.
I don't have one (yet), but the idea of using the silicone tubing as the tip appeals to me.
Offline nanofrog
« Reply #26 on: December 05, 2016, 04:00:05 pm »
It certainly is, and is where I purchased mine (least expensive way to get one in the US AFAIK).
Offline KL27x
« Reply #27 on: December 06, 2016, 05:19:55 am »
We had Metcal everything at the PCB factory I worked at, including the Metcal desoldering guns connected to an STSS or MX-500 and shop air. But everyone was also issued an Edsyn Soldapullt DS017LS. Aside from some of the old ladies on first shift, no one bothered with the desoldering guns. A typical job for the Soldapullt was desoldering 400 through-hole terminal block joints due to someone soldering in the wrong ones or soldering them in the wrong positions. That took about 10 minutes.
LOL. My first Edsyn Soldapult (clone) was amazing. IS amazing. Still have it. Only thing I like better so far is my Edsyn Soldapult 3. I have had the same experience with desoldering stations. Edsyn > station in most cases. Even large jobs. Cuz cleaning/maintenance/tip oxidization. A good soldering iron and a good sucker just keep chugging. Just DON'T add flux, if you don't need it. Flux is what gums up the sucker. (And in most cases, you don't need it! Flux DOESN'T increase heat transfer, beyond improving tip to joint contact area in some cases... even with the solder looking crusty and completely non-flowy, the Edsyn will suck it right out, once you get it to temp. It is easier to get good non-fluxed contact with the joint using an iron, over a desoldering gun, so... Edsyn keeps going.. and going.. and going. My Hakko tip operates bone dry the entire time. Still haven't worn one out.
« Last Edit: December 06, 2016, 05:30:19 am by KL27x »
Offline Ig_sherwoodTopic starter
« Reply #28 on: December 11, 2016, 09:44:12 am »
This tool is very cool and will last for ever ,just need to replace sometimes the o-ring and add a little bit of lubrifican grease to make it works perfectly.
Offline rspt1908
  • Country: ph
« Reply #29 on: January 19, 2017, 06:29:26 pm »
Hello Guys,
May I ask what is the best grease or lubricant for this desoldering pump?
Thank you :)
Offline nanofrog
« Reply #30 on: January 19, 2017, 08:52:39 pm »
Silicone grease, such as that you'd use in fishing reels.
The following users thanked this post: rspt1908
Offline rspt1908
  • Country: ph
« Reply #31 on: January 20, 2017, 02:53:32 am »
Thank you nanofrog :)
Actually I also got a reply from them just earlier.
Maybe they also read this thread and are now allowing shipping of the o-ring with charge from Japan.
They also gave me the dimensions of the o-ring/lip seal which may be helpful for some in this thread. It's 18mm:)
« Last Edit: January 20, 2017, 02:57:53 am by rspt1908 »
The following users thanked this post: Free_WiFi
Offline neslekkim
  • Country: no
« Reply #32 on: January 20, 2017, 07:12:29 am »
would be nice if you copied the youtube link where, so we don't need to type that long thing.. :)
Offline rspt1908
  • Country: ph
« Reply #33 on: January 20, 2017, 07:59:24 am »
Oh sorry about that. here you go :)
Maintainance Video:
The following users thanked this post: blackfin76, neslekkim, oilburner, nikitasius
Offline rspt1908
  • Country: ph
« Reply #34 on: January 25, 2017, 07:17:56 pm »
Good day guys,
May I ask if will this locally available o-ring be a suitable substitute? It has a bigger surface contact on the cylinder compared to the polypak/lipseal used in the pump.
Also is silicone grease still safe to use since this o-ring is made of nitrile rubber?  :)
http://uk.rs-online.com/web/p/seals-o-rings/2952010/
Offline nanofrog
« Reply #35 on: January 25, 2017, 08:14:57 pm »
Yes.
Offline eKretz
« Reply #36 on: January 25, 2017, 11:40:03 pm »
Silicone grease is safe on all rubber. But the seal posted above will not work. That type of seal is designed to seal on the O.D. of a shaft, and the one from the solder sucker needs to seal on the I.D. of a tube.
The following users thanked this post: rspt1908, Free_WiFi
Offline rspt1908
  • Country: ph
« Reply #37 on: May 19, 2017, 12:56:35 am »
Unfortunately it is sold separately. Like it was said in the email, Engineer Tools encourages distributors to carry the spare o rings in their inventory, however, some have yet to do that carrying only the spare silicone tips. For now, they offer shipping the o-ring from their factory in Japan with charge.
Offline boffin
« Reply #38 on: November 16, 2018, 10:51:44 pm »
The seal itself appears to be 16x18x3mm.  Someone would make a fortune (ok a little money), selling a kit of a small pouch of grease, the seal, and a piece of silicone tube to replace the tip for $10.  If I could source all the parts, I'd be willing to do it, but shipping from Canada is horrible (more expensive than even Australia)
Offline neslekkim
  • Country: no
« Reply #39 on: April 15, 2019, 09:52:08 pm »
So today is 2019 12April.
Is someone selling the silicone tube + the rubber o-ring?
the silicone tubes you find here atleast: https://www.precisehandtools.com/index.php?route=product/product&path=74&product_id=116
might be an idea to ask them about the o-rings.
Offline Free_WiFi
  • https://tinyurl.com/y5nhpt2x
« Reply #40 on: November 12, 2019, 07:37:23 pm »
Technical specification of this o-ring/seal :
Type : Piston U-Seal
Dimensions :
OD : 19 mm.
H   : 3,5 mm.
Link for Piston U-Seal
www.aliexpress.com/item/32891032842.html
The silicon Nozzle/Tube
Dimensions :
OD : 4 mm.
Link for the silicon Nozzle/Tube :
www.aliexpress.com/item/32858462618.html
Offline boffin
« Reply #41 on: November 13, 2019, 06:24:01 pm »
I took mine apart at the weekend, cleaned all  the existing goo, covered it with a good spray of jig-a-loo (silicone lubricant), and it works like a charm now.
Offline nukie
« Reply #42 on: November 19, 2019, 11:52:31 pm »
I have this since October 2012. I have at least 4 suckers in my drawer which I rotate use as I wish. I clean them end of every month. The SS-02 worn out the release trigger. It won't lock. It's made out of aluminium and friction on the stainless plunger shaft chewed the release button. Fortunately I could reverse the trigger so I could get a second life. I don't use it that often anymore. It's a poor designed not for everyday use.
The following users thanked this post: nikitasius
Offline 2X
  • Country: gr
« Reply #43 on: April 15, 2024, 10:08:09 pm »
Hello,
does anyone find a site/seller that sells the Piston U-Seal?
