I just finished decyphering the matrix tray setup video too. Not that bad:
0:00:00 - Introduction to 4C Custom tray Mount Setup, cleanup tabletop
0:02:51 - Start introducing User device
Program Definition / "User Devices" button under "Customer column"
00:04:01 - "Machine Configuration" to find new tabletop items?
00:06:15 - "Matrix Tray holders Tab "CustomMatrxTrayMount4C" .. 2Pos" - case sensitive
Lets you configure you the MOUNT / HOLDER (not the tray)
07:45 - Bottom - "Tray Mounts" configures tray locations
08:15 - Matrix tray Holder options defined
09:50 - Fiducial locations on the Tray HOLDER
Used to easily use camera to find corners
11:23 - Tray mount position (UL/UR/etc)
X/Y from the Tray Holder 0,0
19:22 - Configure up custom tray
"Matrix Trays" tab under "User Defined Devices"
Configured from X/Y from defined reference corner (top left, right/etc)
Teach Tabletop Devices - This is where we are going to put whatever matrix tray HOLDER into the machine. It establishes it's XY coordinates.
Trayholders Tab - Add in the tray you want to put onto the holder
Select any pocket (highlights) and move to it to see if it's correct
Somehow Ref1 and Ref2 (Table objects) refer to the fiducials drilled into the matrix tray mount
HAHA! Right click on a pocket (TL, BR, BL) and assign them as references REF #1, 2, and 3. Pick them off with the controller, and it's aligned!
When filling trays (teach tabletop devices / User / Matrix trays) right click and use popup menu to establish what's in there (picked, empty, disabled, whatever). FILL - totally fills the whole thing.
