Hi all
Have a look at this thing of total crap, I bought this off Amazon, (needed the power unit for hot knife tool)
This has now has been removed from Amazon... Thankfully...
These are for sale all over the NET so please look out...
Anyway what do you think... I personally love that main power switch...
Why the power switch, it is a dull standard mains switch, available from any number of manufacturers, 6 amps at 250 VAC are way overdimensioned, unlikely to be a problem (if it actually meets the specs)?
Please note UK Voltage is 230 +10/-6% and that's not a British standard plug...
220 Volts, 230 Volts, +- something, doesn't make a real difference in terms of safety. Now plugging a device designed for that silly 110 Volts thing the 'murricans have going on into a sensible mains system would be another thing.
If the device wasn't advertised as having a standard British plug then you can't complain about it not having one. Anything without a standard IEC socket at the back is suspicious anyway.
The one thing I can see from the images is that the power switch is only for one mains conductor - one must never assume which conductor is hot and which is neutral.
Hmm, having the red wires neatly and safely(!) separated from the yellow wires and the PCB would be a very good idea too. As would be having the metal front connector being connected to protective earth.
