Author Topic: Glasses to dim bright LED lights?  (Read 1890 times)
Offline drummerdimitriTopic starter
  • Country: lb
« on: October 17, 2018, 08:47:35 pm »
I'm looking to inspect some LED lights under max brightness (100W LED) without going blind and sunglasses/red glasses for laser light don't block out enough light to make it comfortable for viewing bright lights so what would you recommend for my needs?
Will welding glasses block out the light? I want to be able to see the strips of light to see which ones are damaged.
Offline Bratster
Re: Glasses to dim bright LED lights?
« Reply #1 on: October 18, 2018, 01:06:58 am »
Welding goggles would definitely work, you just have to be careful with what shade you get so it's not too dark.
Something intended for oxy-acetylene welding or plasma cutting would probably be okay.
Sent from my Fi Moto x4 using Tapatalk
Offline Nusa
« Reply #2 on: October 18, 2018, 02:22:59 am »
I think I would engineer a camera arrangement to achieve the same result. No reason to risk damage to your eyes or limit yourself to the visible spectrum.
Offline thermistor-guy
« Reply #3 on: October 18, 2018, 02:57:09 am »
I'd check out laser safety glasses that have sufficiently high Optical Density (O.D.) in the wavelengths of your application. Assuming you are looking at "white" LEDs with a strong blue component, then maybe the LG10 or LG12 from Thorlabs to block blue and blue-green wavelengths: https://www.thorlabs.com/newgrouppage9.cfm?objectgroup_id=762.
Thorlabs should be able to help you, if you can provide some spectral data for the LEDS in question.
Offline NiHaoMike
    • Facebook Page
« Reply #4 on: October 18, 2018, 03:51:57 am »
A pinhole camera projecting onto a paper screen works surprisingly well, and in fact is one suggested cheap and safe way to view a solar eclipse.
Online tooki
« Reply #5 on: October 19, 2018, 11:02:04 am »
Or if you already have a camera suitable for this type of inspection, you could put a neutral density filter on it and use that.
Offline David Hess
  • DavidH
« Reply #6 on: October 20, 2018, 01:36:02 am »
Gas welding googles like these would be ideal.  Standard inexpensive 2 x 4-1/4 inch shaded welding lenses can be used but I am not sure what grade would be suitable for bright LEDs.  Or you can go for gas welding googles for extra style.
I used googles like these to watch the last eclipse.  Do *not* use them for arc welding as they do not protect your entire face from ultraviolet light like a welding mask does.
Offline Kjelt
« Reply #7 on: October 20, 2018, 08:40:28 am »
I second the camera setup, no reason to risk your eyes with experiments.
Glasses that are lcd dimmable probably will cost more
