I found a Yihua-branded 15V 2A bench PSU in a bin. It seemed untouched, but the 1A mains fuse was blown and the transformer primary measured 8 ohms. It powered up OK on a bench supply so I replaced the transformer. The mains lead had been cut off so I replaced it- there was the usual cheapo Chinese single pole mains switch switching the neutral, which is a ploy to enable the termination of the mains neutral somewhere; the live being terminated on the fuseholder. As I eased the heatshrink off the end terminal of the fuseholder, the whole contact just fell out of the back of the holder. I'm not clear how the thing was supposed to be held in, and a coil spring fell out other end of the holder. The contact is made of a very thin tinplate, as are the sprung 'fingers' in the free cap, which have no pressure to hold the fuse at all. I replaced it with a Bulgin out of the parts drawer and all is well.
I thought it was worth a warning.
The PSU itself, Yihua 1502USB, is particularly horrible- with a single 2N3055 on the back panel. It does not deliver anywhere near its claimed output current at 15V, and there is a weird 'RF meter' bar graph to test mobile phone signal strength that I have not managed to get to the bottom of.
BT
