I have found in Brazil a similar (maybe identical) rework station Solden SE880D to Quick 861DW, concerning taxes and shipping costs from abroad it seemed worthy for me to buy it here in Brazil:
http://produto.mercadolivre.com.br/MLB-704834891-estaco-de-ar-quente-solden-ajuste-temperatura-se880d-_JM.
I asked Quick Global if they are the same models and its first contact employee wrote it was a Quick 861DW:
“…SOLDEN SE-880 is QUICK861DW rework station. …”.
So I bought it, but when I received it I was surprised because I did not see the ESD grounding socket at the rear panel, although there is an ESD label at the front panel.
I have already emailed Brazilian Solden 2 times, why they put the ESD label on the front panel, but there is not an ESD grounding socket, so I asked them gently how ESD do work on its model. No answer received.
I also emailed again Quick Global about it and its first contact employee answered this:
The SE880D(861DW) you buy this time doesn't have ground wire connection, which was added later for improvement of rework station.
However, the using would not be affected as the rework station is used to rework of components. With the nozzle, it doesn't touch components directly.
…”His first contact employee asked me about which components I was going to rework with Solden SE880D, I answered back which components should I avoid and
high extra procedures should I take to avoid ESD problems.
Then a second contact employee from Quick Global answered me:
Speaking of ESD issue, please let me put like this.
1. ESD is a kind of product standards in this field, which includes many aspects. Fyi, nearly all the manufactures put ESD on their products so far whether it's real or not.
2. As I said above, ESD actually consists of many things, such as grounded power cord, anti-static paint on the housing and cable, grounding socket etc. Regarding our QUICK861DW, we used the grounded power cable, the housing maybe painted with the ESD paint. As for the grounding socket, as Kerry explained, the product you bought maybe not have it because it's improved later (step by step).
3. You know, QUICK861DW(SE880D) is just a rework station. You talked about ESD many times. Please let us know what your real purpose is so that we can understand you correctly.
…”.So is it worthy to keep a rework station without an ESD grounding socket?
Which components should I avoid and which extra procedures should I take to avoid ESD problems?
