Author Topic: Hakko Fr-300 desoldering tool  (Read 99722 times)
Offline staze
  • I _might_ have a problem...
    • Everybody Staze...
Re: Hakko Fr-300 desoldering tool
« Reply #200 on: April 01, 2015, 05:58:48 am »
The Hakko Tip Tray is solid aluminum. I put a rubber pad on the bottom of each to help keep them from sliding easily on the shelf. I could have made something similar/better on the lathe and mill, but these came with other Hakko equipment and work well enough.
Just ordered one. Did you use a step bit to widen the holes for the N50 tips, or...?
“Give a man an answer, he’ll keep his job for a day. Teach a man to Google, and he’ll be employed for a lifetime”
Offline iRad
  • Are you sure it's safe?
« Reply #201 on: April 01, 2015, 01:08:23 pm »
Just use a 21/64 HSS twist drill bit. Depth of the larger boar hole is only about 1/2", as the original hole allows the tip to recess further.
I also drilled several of the other holes deeper into the holder, so that some of my longer tips would seat further into the holder. Hakko boars the holes too shallow in my opinion.
Offline staze
« Reply #202 on: April 01, 2015, 02:48:31 pm »
21/64?! Now I know you do machining. That is a very odd size (not something in my bit sets). :p
Offline iRad
« Reply #203 on: April 01, 2015, 03:06:07 pm »
Not odd at all. Any good HSS bit set increments by 64ths.
An 11/32 bit will also allow the tip to fit, if just a tad bit loose. Next size up from there by 16ths of an inch is 3/8, but the hole is pretty sloppy loose at that point.
Offline staze
« Reply #204 on: April 01, 2015, 04:33:22 pm »
Cool. I have very few drill bits, so I'll have to pick one up... and resist the urge to just buy a HF set... because nothing good could ever come of that.
Offline staze
« Reply #205 on: April 04, 2015, 07:48:11 pm »
Okay, bought a bit set that had a 21/64ths.
Curious, what size are the holes that you drilled for the cleaning "pins". I have the 1mm and 1.6mm ones, and kind of curious if I should just drill two 1/16th holes (so I don't have to worry about which is which).
Offline iRad
« Reply #206 on: April 04, 2015, 09:01:29 pm »
I just drilled two 1/16 inch holes...
Offline staze
« Reply #207 on: April 04, 2015, 09:26:35 pm »
Cool. Depth?
Also, since I haven't drilled a lot of Al, did you bother with any kind of cutting fluid (I was just figuring some 3-in-1 oil... since I don't have any rapid tap or anything), or just go slow (drill, clear, drill, clear)?
Offline iRad
« Reply #208 on: April 04, 2015, 11:08:33 pm »
...or just go slow (drill, clear, drill, clear)?
Yep, and about as deep as your bit will easily go. Careful not to break the bit off inside the hole.
Offline staze
« Reply #209 on: April 04, 2015, 11:32:09 pm »
Cool. For those interested, I got some "Everbilt" anti-skid self adhesive pads that are 2" (51mm) in diameter, and they fit the bottom of the holder perfectly.
Offline iRad
« Reply #210 on: April 10, 2015, 02:13:17 pm »
Can't you pester Hakko to make a nozzle for the FR-300, that is similar to N60-08 / N60-09 ?
This is quoted from the FR-400 thread, but worthy of posting here.
A nozzle similar to the N60-08 / N60-09 (available for FR-400) would be very useful to FR-300 users.
Offline gmit77
    • Batter Fly
« Reply #211 on: April 10, 2015, 02:24:52 pm »
Yes, agree. Let see what HAKKO will reply.
Batter Fly
never stop innovating
Offline staze
« Reply #212 on: April 11, 2015, 10:03:49 pm »
iRad,
Do you also have any T18 tips? Think I need to widen the holes on the tip holder just a tiny bit for them.
Offline iRad
« Reply #213 on: April 11, 2015, 10:18:46 pm »
Just in the junk drawer. Haven't used them in ages.
Offline staze
« Reply #214 on: April 11, 2015, 10:28:45 pm »
Lol. Elitist. :p
Offline gmit77
    • Batter Fly
« Reply #215 on: April 13, 2015, 06:09:26 am »
it seems the FR-300 does not have enough thermal capacity to work with such shapes
Batter Fly
Offline neslekkim
  • Country: no
« Reply #216 on: April 13, 2015, 06:44:59 am »
After using the fr-300, I'm not sure if I believe that, we are not talking about the biggest ones, but one simple with a slotted hole.
But I would guess that Hakko will have you to get the fr-400 for those jobs, I only want to be able to unsolder those small powerconnectors with spades.
Offline gmit77
    • Batter Fly
« Reply #217 on: April 13, 2015, 06:47:59 am »
hello, I guess it is a first reply since the N60-08/09 are very new. I'm sure they will consider same shape smaller dimensions for future.
Batter Fly
Offline neslekkim
  • Country: no
« Reply #218 on: April 13, 2015, 06:52:53 am »
I hope so :), maybe the chinese will make an clone :)
If I did professional use I can see that the 400 is a better choice, but for hobby the 300 is very good.
Offline CRi
« Reply #219 on: June 25, 2015, 10:52:06 am »
sent PM
Hi gmit77,
I also would like to buy a Hakko FR-300, is it possible to have a discount code?
Thanks in advance !
Offline gmit77
    • Batter Fly
« Reply #220 on: June 26, 2015, 03:18:53 pm »
sent PM
Batter Fly
Offline nzCdog
  • Corey
« Reply #221 on: November 24, 2015, 03:48:55 am »
Dredge, I know ;)
Do any users have comments on this desolder device, now that it has been around a while?  Thoughts?  Thanks in advance  ;D
Offline helius
« Reply #222 on: November 24, 2015, 06:30:02 am »
Some comments in this thread: https://www.eevblog.com/forum/reviews/hakko-fr300-do-you-recommend-it/
It seems like there were some infant mortality with early units, which has been fixed.
Offline nzCdog
  • Corey
« Reply #223 on: November 24, 2015, 09:12:38 am »
Thanks man, very helpful
Offline CkRtech
« Reply #224 on: January 08, 2016, 12:52:58 am »
I have had a bit of trouble with working the cleaning pin into the tip and pushing it through to the chamber whereas it used to be mostly easy (with still a bit of resistance as I push it through).
Any cleaning/maintenance suggestions to help me out?
