this video may help
No, sorry but that doesn't answer OP's question (and I have the same question) at all.
I believe we've both worked out how to get into settings and modify them. What we can't work out is whether or not it's possible to enable sleep and auto-off at the same time. Hakko's documentation for the iron (once you create an account on their documentation site, so you can hunt the current version down and download it) isn't so much bad as it is
f*&king woeful.
As best I can tell, this is what is possible;
- Setting a sleep time between 0 and 29 minutes works as you would expect, which is to say the iron begins to sleep (displaying 'SLP') between 0 and 29 minutes after it is placed in the holder. However, the iron does not turn off automatically after 30 minutes
- Setting a sleep time of 30 causes the iron to turn power to the element off completely (displaying '---') after 30 minutes in the holder. However, it does not enter the sleep state at all prior to that
- If you don't wish to use the sleep or auto-off function at all, unplug the switch cable to the iron holder. There is no software disable for the feature
As best I can tell, there is
no way to enable sleep AND auto power off functionality together, which seems like a crazy omission on Hakko's part. Granted the FX-951 isn't a new model, but then my FM-204 is no spring chicken either and it's quite happy to put itself to sleep after 0-29 minutes, and
also turn itself off after 30. Both features are independently switchable in the configuration, though the auto-off seems to be fixed at 30 minutes if enabled, while the sleep pause can be set like the 951.
