Author Topic: Hint for Agilent DSO-X 2002A Vs Rigol DS 1054Z  (Read 15976 times)
Offline UltronTopic starter
Re: Hint for Agilent DSO-X 2002A Vs Rigol DS 1054Z
« Reply #25 on: August 12, 2015, 02:05:11 am »
Yeah ...! after huge efforts I did!  :phew:  ;D
I follows these instructions by the "DSOX2000 and 3000 series - licence , have anyone tried to hack that scope ?" topic, page 51
Hi!
There is easier way to downgrade.
I have flashed 2.39 a long before I found this site. But now I have 2.35 with just PC and USB-key ;)
All has beed checked today on my MSO-X 2012 (originally it was standard 100MHz + MEMUP update with 2.39 firmware).
1. downgrade to 2.37 (it just works)
2. unpack 2000XSeries.02.37.2014052002.cab (ex with WinRAR)
3. extract file infiniiVisionLauncher.exe from infiniiVisionSetup.cab (2.37) (ex with WinCE CAB Manager)
4. unpack 2000XSeries.02.35.2013061800.cab (ex with WinRAR)
5. open infiniiVisionSetup.cab (from 2.35) file in WinCE CAB Manager, find infiniiVisionLauncher.exe on list and delete it
6. add infiniiVisionLauncher.exe (from 2.37 cab) to file list and set all properties like in old file (flags: uncheck all; location: \Secure\InfiniiVision; Hard-coded path checked)
7. file->save and exit WinCE CAB Manager
8. calc MD5 of edited infiniiVisionSetup.cab and update it in recipe.xml file
9. compress all files (ex with CabPack) from 2.35 firmware with edited infiniiVisionSetup.cab
10. flash new file
One detail: In the CabPack software it's important to setting the Compression type to MSZIP
In attachement the faked file for downgrade from 2.37 (or 2.39) to 2.35 for easy hack.*
Thanks!
*I can not attach the file, is too big!
« Last Edit: August 12, 2015, 02:11:15 am by Ultron »
Offline TopLoser
« Reply #26 on: August 12, 2015, 08:47:07 am »
Well done, I'm pleased it all went well  :)
« Reply #27 on: August 12, 2015, 06:31:37 pm »
ARGH!  :o  I looked for MSO cable (8 ch) and i find out that the price is about 400$$!!
We are crazy? For a cable?
Offline neslekkim
  • Country: no
« Reply #28 on: August 12, 2015, 07:16:40 pm »
Did you read post #9 in this thread?
« Reply #29 on: August 12, 2015, 09:13:22 pm »
Ok, i read it, but I did not understand...  :-\
Offline mauroh
    • Mauro Pintus
« Reply #30 on: August 14, 2015, 08:30:10 am »
For low frequency digital signals you don't need the original Agilent "digital" cable but just a flat cable from an old PC.
Italian: Per segnali a bassa frequenza non serve il cavo originale Agilent ma ti basta un cavo piatto recuperato da un vecchio PC.
Mauro
« Reply #31 on: August 18, 2015, 02:23:48 am »
Grazie! Ho visto solo adesso che l'imbocco del cavo è identico ad un classico IDE 40 Poli. Ne utilizzerò uno per UltraDMA, con un singolo filo di massa per ogni filo di dati.
Thanks. I just see. The hole for DIGITAL cable is the same than old IDE PC cable one.
I am going to use it one for UltraDMA, which have a single ground wire for each wire data (i can gain some MHz for maximum frequency measure range)
The following users thanked this post: blueangel
Offline mauroh
    • Mauro Pintus
« Reply #32 on: August 18, 2015, 07:57:43 pm »
You are welcome :).
Let us know the performance you will achieve.
Enjoy your new toy
Mauro
Offline blueangel
  • Country: tw
« Reply #33 on: December 15, 2016, 06:51:16 am »
[/quote
Remember that each channel should be added 100K resistor.
Offline balestrino
« Reply #34 on: August 24, 2017, 08:18:34 am »
Hi
i'm trying to hack my Agilent with firmware 2.12 but leds keeps flashing and nothing happens.
i tried different usb key as fat16 and fat32.
Also I cant find on internet firmware v. 2.35
anyone knows where to download the old 2.35 firmware?
thanks!
Offline LA7SJA
  • Country: no
  • Acting user manual reader & forum search engine
« Reply #35 on: December 18, 2017, 08:16:17 am »
Did the 2.35 firmware help you in any way? I would like to take down the file when you don't need it anymore.
Johan-Fredrik
"If at first you don't succeed, skydiving is probably not for you"
Offline balestrino
« Reply #36 on: December 18, 2017, 08:39:00 am »
Yes you can remove the file. thanks!
anyway i found the 2.5 online and it's the same file you sent.
I tried to update the firmware but after that the scope hangs on boot and the led starts to blink  :-//
so i sent it back to Keysight/Agilent and they now are sending back a refurbished unit (and also calibrated!)  :clap:
they say that is in warranty because of a know bug on updating firmware (mine was very old firmware, if i recall correctly was on 2.12)
The following users thanked this post: LA7SJA
