Hello
I'm starting to experiment with CMOS ICs, so I bought an anti-static mat and bracelet from my local electronics shop. They are the
Velleman AS4 mat (surface resistivity 10e9 to 10e11 ohm/m2) and
AS2 wrist strap with 1 Mohm resistor.
I didn't ask the shop guys how to connect and use them, thinking it would be obvious (silly me!) but the products don't have any manual. I just checked the Velleman site and I couldn't find any instructions there either.
The mat only has one button, where you snap its own lead. I connected the other side to the ground pin of my scope, since it's always connected to earth ground, even when the instrument is turned off (I just verified it with my meter.) That leaves the wrist strap, which has another crocodile at the end of its lead.
Is it ok to connect it to the edge of the mat, next to the other grounding lead, as I have seen in some videos and pictures online?
Secondly, is there any hobbyist-level procedure (that doesn't involve buying expensive insulation testers) to measure or just validate an anti-static equipment setup? I just tried with my meter, but it can't read Gohm resistance. (It does read the Mohm of the bracelet, even between the grounding lead and the inside of the strap.)
For instance, I'm considering buying these boxes, because they fit my preferences for part storage:
http://www.ebay.co.uk/itm/221377178580 But the brand and seller are such no-names, I'd like to verify that the boxes are actually anti-static before I buy several. Can I do that?
