So I found this IPL machine in the electronics recycling bin and I decided to take a few useful/interesting parts. It's supposed to produce broad spectrum pulsed light and I thought I would contain a normal xenon flash bulb to do so. It turns out that it doesn't and a quick google did not turn up an answer to how it works - so i'm asking for your help in explaining it.
Overview of parts.
Head with coolant hoses coming in.
Head removed, wires coming in are 2 thick ones going to the light source, and narrow ones to peltier cooler.
Bottom part removed (peltier cooler connects to the "nozzle" part (touching the skin) and prism to cool it.
Prism is broken, not sure if this was the reason it was discarded or it happened afterwards. I used to have a collegue who designed these machines and he mentioned they had lots of problems with the reliability of the prisms and the suppliers not meeting their specifications.
View down the light source, only two wires coming in and a resistor connected across the terminals (see first pic).
Reflective foil on the outside of the prism to keep light in
Pretty =)
The light thingy has glass rods glued to the front (are they lenses or is light produced in them?).
They are placed over the gaps between the metal bars (is that where the light is coming from?).
Metal bars are held on with conductive foam/glue.
Beneath it is some other metal and maybe ceramic substrate/isolator. Cables are connected to either side as seen, is there some high voltage that causes arcing to produce light? This is in open air? Cables are 12 AWG which suggests decent current (and low voltage? they are not marked with any voltage but have fairly thick silicone insulation).
What a coincidence.
And that's all.
Any input or comments is very welcome.
