Hi Folks,
I recently bought a Duratech TS-1564 soldering iron. It's got a conical tip which I want to change to a chisel tip.
I can't find any instructions regarding how to do this.
I can't see how the tip is attached - does it just push on? I've tried (gently) to remove the tip but it seems to be on pretty tight. Is it attached somehow? Does it just pull off?
Any help with this would be much appreciated.
Cheers,
Chris
