What do you mean 'stubborn'? Just buy a good quality allen key and use (the) force.
"Stubborn screws" here means that:
- they got stuck
- someone already worked on them before me and inner hex slot has become bigger, so that allen key simply doesn't have good grip
I found a way and removed all these screw grubs, maybe that will help someone. To do this:
1. find am appropriate TORX screw driver, its tips is conical and has sharp edges.
2. grind the end of the tip, so it becomes thicker and shorter until it can hardly get into the inner hex hole of the screw.
3. _force_ this screw driver into the hole, its edges will cut into the hex slot
4. turn it, applying pressure to the screw driver, trying not to break the knob
5. enjoy
