Author Topic: "Hulko" 861D+, Quick 861DW Clone  (Read 6022 times)
Offline TheBayTopic starter
  • Country: wales
« on: October 14, 2018, 03:55:35 pm »
Spotted a few of these on eBay/Aliexpress, they look very similar to the Quick 861 series, certainly the same external design.
Couldn't find any reviews or teardowns online but browsing Aliexpress I noticed someone had left a review and done a bit of a teardown, so posting these pictures on here.
I wonder how well these perform as they are quite cheap, looking at the "Teardown" I found they even have the mains filter on the back, however the PCB's look different to all
the Genuine Quick units I've seen, just looks like a single triac on the control board. Though the motor looks to be brushless by the number of wires coming off it.
These cost about the same as 3x 858d's in the UK but half the price of a Quick 861DW (If these are genuine on eBay)
https://www.ebay.co.uk/itm/861D-Digital-Soldering-1000W-Rework-Station-Hot-Air-Gun-220V-240V-with-Nozzles/232661767326
https://www.aliexpress.com/store/product/Digital-861D-Rework-Soldering-Station-1000W-Hot-Air-Gun-Hot-Air-Rework-Station-Nozzles-Grounding-Line/703508_32865649014.html
« Last Edit: October 14, 2018, 03:59:10 pm by TheBay »
Offline mcinque
  • I know that I know nothing
Re: "Hulko" 861D+, Quick 861DW Clone
« Reply #1 on: October 14, 2018, 04:10:03 pm »
Quite disgusting  ;D
Offline Klikgamee
« Reply #2 on: November 20, 2018, 07:20:33 pm »
I have bought both quick 861DA and hulko 861D+
I have tested both quick 861DA as the hulko 861D+
If have found that the ‘’ clone’ hulko 861D+ performance
Very good when u calibrate iT
I have done many repair jobs using the hulko 861D+
As for the  iPhone a10 CPU removing and reballing puting
Back and the iPhone stil workig  after the repair
For this station i use bent nozzles from the quick 861dw
They fit also on the hulko 861D+  dont go lower then 6 mm nozzle
Very good no difference to quick 861
Offline oolloo
« Reply #3 on: November 30, 2018, 10:48:34 pm »
what about the fact that hulko has 8A fuse and Quick has higher amp fuse?
can you post inside and outside pictures of the Quick please?
« Last Edit: November 30, 2018, 10:58:00 pm by oolloo »
Offline guazan
« Reply #4 on: October 04, 2019, 05:18:35 am »
an 8A fuse is equivalent to 1840W of resistance. I have the MLINK H6 station my budget is not very high we will notice a difference if I buy the
 hulko 861D + thanks.
