I have been reading this forum for more info about cheap hot air stations and like you, became intrigued with the ubiquitous 858D clones out there and the numerous issues associated with them. I could not deny the incredible price to performance ratio of these machines if they are properly fixed/modded so I decided to order a 110V 858D clone from Amazon for just 39$US shipped. The one I ordered was branded “Newalacox” and came with a bunch of extra accessories like tweezers, solder sucker and extra heating element.
This particular model seemed to be slightly better designed and constructed than the others when I had a chance to examine it up close. The wand cable and power cord were detachable unlike the more popular Atten. After opening up the chassis, I tested the wiring and they were properly connected although the color coding was nonsensical. Live wire from main went directly to the switch and the neutral went to PCB. Fuse was inline with live via a removable box under the IEC power socket. Ground wire from main was linked to the ESD socket and to the hind transformer mounting screw. Another separate ground wire was linked to the PCB from the front transformer mounting screw. Tip of wand and screws were grounded. Soldering seemed adequate and no cold joints were detected. I was pleased to see a mounting screw next to the two button switches on the PCB. This will help minimize PCB flexing when the buttons are pushed. Now to the negatives...
Plastic front and back panels. I would have preferred that they used metal but plastic does provide some insulation from a safety standpoint. Still, metal is more durable and dissipates heat better.
Uncrimped wire connectors. They soldered the ground wires to the connectors but forgot to crimp them. I corrected this easily with an electrician tool.
The metal socket on the front panel was ungrounded. I fixed this by looping bare wire around the socket on the interior side and twisting the ends together to form a soldering point for one end of a jumper wire. The other end of the jumper went to the grounding pad on the PCB. During my soldering, the edge of the plastic panel melted a little from the heat coming from the iron tip. Luckily, it was minor damage and not noticiable from the outside. Be careful not to get very close to the cheap plastic when soldering.
Wand was glued together. Even though there was four screws holding the two halves together, the upper portion was glued with a mastic type adhesive probably to make the top air tight. There was no plastic collar that screws on top like the older wands. The collar was molded as part of the two halves. No doubt this was a cost saving measure. I was unable to check the wiring and PCB inside without risking damage to the wand. Kind of defeats the purpose of providing an extra heating element.
Performance of the hot air wand was quite good. I was able to remove SMD components easily. The heat seemed very stable. Air velocity and temperature controls were smooth. Measuring the heat at the tip of the nozzle yielded a +/- 20 degrees C difference from the display which was not too bad. I have not tried the calibration pot yet. The unit did get very warm after an hour of operation. Hopefully, that large heatsink on the triac will do its job. Changing the nozzles was fast and easy...just line it up with the small channel, insert and twist to lock. All in all, after tinkering with it, this purchase was worth the price. I hope it lasts more than a year...
