That looks like the good stuff - "150C No defect, 200C No defect, 250C No defect, 300C Very slight, 400C Slight indent, 500C Burnt." means it will withstand momentary contact with a soldering iron tip at 370 deg C (700 deg F) and has no problems with conducted heat or solder splashes.
Its got two studs fitted so you can use one for grounding the mat and the other for a wrist strap (not supplied).
