Thank's dude, could you guess the wattage of it as well? Cause I have really no clue how it can burn off like it did in my case. Did not found any schematics to read off it's purpose in the circuit. BR
I'd guess 3W.
So do you consider this still to be the best price/performance cheap digital bench power supply in the UK?
I don't know about the "best" in the UK but a very good hobby PSU in my limited opinion. To be the "best" you have to look at so many different things I know too little about.
There are so many to choose from and I don't know enough electronics wise to say one is better than another for whatever reason.
I know I still love mine after a couple years of good solid use. It's still quite accurate and the fan doesn't squeak or rattle so it's still very quiet.
All the safety features still work as they should and that part I have tested to the limit i'm not too proud to admit!
I would certainly recommend it to anyone looking to buy 1. I have no complaints at all with mine. I found it easy to use and learn how to get the most from it and found it very forgiving as I made lots of newby mistakes. There are a few guys here on the forum have them too and can usually tell you how to fix it if needed or open theirs to help get parts numbers or whatever.
At a guess it has to be up there with the best surely.
