Hi guys, I have finally got around to finishing testing all the 521Cs tubes, well the ones I could anyway. I ended up replacing 5 tubes eventually, quite a large number really - most of the failing tubes had gone gassy. Main caps OK, fan works, transformer ok.
I used my uTracer- (after I broke it
, then repaired that as well!)
This is one of HP not good designs I think. The frequency divider circuit styled after a phantastron, to me , looks like a charge pump, and with differences in loading of each divide by ten circuit (whether it is in 1/10, 1 or 10sec count mode) results in different divisors (9,10 or 11) , you can adjust each stage to divide correctly. The different range selections obviously load the divisors inconsistently, so if you count in the 'wrong' range the answer can be out by 10% or so. I am sure when it came out of the factory all the caps were in value etc and it didn't do this but now it does. I think I am going to leave it. Otherwise it works well.
