I have used many different laptops and noticed that most of them have poor (in my opinion) volume control logic. Laptops typically have three control for volume accessible as either dedicated buttons or via Fn functions - volume up, volume down, mute/unmute. There at least two different logic schemes for functions of each button. One of them is by far the most popular, but far less useful than the other IMHO.
Logic A, by far the most prevalent (>90% of cases):
- Volume UP - increases volume AND disables MUTE mode
- Volume DOWN - decreases volume AND disables MUTE mode
- Mute - enables/disables MUTE mode. Does not affect volume setting.
Logic B, less popular, more useful:
- Volume UP - increases volume. Does not affect MUTE mode
- Volume DOWN - decreases volume. Does not affect MUTE mode
Logic A is annoying and makes MUTE button practically useless. Volume keys (HW or SW) should make sound level control easier than though mouse or application. User would use mute function mostly to a) disable sound if it is not needed or b) disable sound that is too loud, then reduce sound level and unmute again.
However, logic A makes case b) practically unusable and annoying because volume up/down unmutes sound again and blasts your ears open (or wakes up neighbours). With case b) gone, dedicated mute button is not very useful as decreasing volume to 0 achieves the same goal as crippled mute.
On the contrary, logic B is much better because buttons function independently and mute mode is not disabled by volume up/down. This allows for more control and does not require unnecessary mental planning. Professional audio gear employs logic B as well (to my knowledge).
Case "
sound is far too loud", logic
A, unnecessary many steps to reduce sound volume:
- press mute to save ears
- cannot press volume down as it will unmute
- find and disable/exit sound generating app
- press volume down
- enter sound app gain
- listen in normal sound level
Case "
B, very easy:
- press volume down
- press mute to unmute
For example:
On older Acer laptops (3800 series) logic B is in effect when special ACER keyboard driver is active, but logic A is active when driver is uninstalled. 3800 has Fn volume keys.
Older Thinkpad series laptops have dedicated HW buttons, but for some reason use logic A.
Newer Dell/HP laptops with Fn volume buttons have logic A to my knowledge.
There should be SW and HW solution for this. I found that "Voimeeter" audio driver for Windows uses logic B, but it can mess up windows audio for good in some cases. On HW front, I cannot find newer laptop with logic B.
Which logic (A or B) do you prefer? Why logic A even exist if it has significant drawbacks? Can anybody recommend manufacturer of laptops or SW solutions with logic B?
