Author Topic: Metcal MX-500 dual ouputs  (Read 12171 times)
Offline JesterTopic starter
« on: May 16, 2016, 10:34:43 pm »
I often use two soldering irons simultaneously to remove components from a board.
I'm thinking of getting a Metcal MX-500 that has dual outputs, my rational is replace two mediocre soldering stations with one good (dual) soldering station. I now see there is a control that appears to either select one output or the other but not both.
Can any MX-500 users confirm that you can only use one output at a time?
Offline Fsck
  • sleep deprived
Re: Metcal MX-500 dual ouputs
« Reply #1 on: May 16, 2016, 10:36:25 pm »
you're correct. it's a switchable 2-port unit. one iron is powered at a time.
"This is a one line proof...if we start sufficiently far to the left."
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #2 on: May 16, 2016, 10:58:26 pm »
The MX-5200 has simultaneous outputs, however warm-up time on switch-over is quick enough when switching that it's not a big inconvenience
Day Job: Mostly LEDs
« Reply #3 on: May 16, 2016, 11:23:00 pm »
I will consider the 5200 then, thank you.
Offline SteveyG
  • Soldering Equipment Guru
« Reply #4 on: May 18, 2016, 08:34:31 am »
I have the 5200 (I did a video on it a long time ago). It's worth it if you plan to use the Metcal desolder gun as that does take quite a while to get up to temperature, but otherwise as Mike said the iron is hot in a second or two.
YouTube Channel: https://www.youtube.com/user/sdgelectronics/
Use code: “SDG5” to get 5% off JBC Equipment at Kaisertech
Offline neslekkim
  • Country: no
« Reply #5 on: May 18, 2016, 05:40:14 pm »
Two soldering irons to remove an component?, what about tweezers?
https://www.hakko.com/english/products/hakko_fx8804.html
etc...
Offline Wirehead
    • Wirehead.be
« Reply #6 on: May 19, 2016, 06:37:00 am »
What's the advantage of a tweezer system when comparing to a hot-air station and regular tweezers? Seems to me like that would be a more useful addition to the bench?
"to remain static is to lose ground"
Offline neslekkim
  • Country: no
« Reply #7 on: May 19, 2016, 06:40:38 am »
Instead of this I would guess it gives lot of advantages.
« Reply #8 on: May 19, 2016, 07:15:06 am »
etc...
2 irons are better - more maneuverable. with tweezers you need to get them in line with the component to get good thermal contact on both - this is easier to do with 2 irons. I have some Metcal tweezers but can't remember when I last used them.
Offline zapta
« Reply #9 on: May 19, 2016, 02:27:42 pm »
Or those Metcal part removal tips
Offline The Soulman
  • The sky is the limit!
« Reply #10 on: May 19, 2016, 06:05:49 pm »
I use a weller wdd161v dual soldering station it can power two 80 watt (or less) soldering irons simultaneously,
there is one button to toggle the temperature adjustment buttons and display between the two channels.
For what it's worth..
« Reply #11 on: May 20, 2016, 01:50:11 am »
Those are a PITA to get the part  out of afterwards. the only useful  types are the wide ones for pulling off SO8's etc. and even then only when you have enough to remove that it's quicker than braid etc.
Offline Smith
« Reply #12 on: May 20, 2016, 04:58:12 pm »
I use a Weller WD2M (basically a WD2 with built in USB support), it has 2 ports with 160 watts max total power. I regularly use 2 channels at one time, but it's also nice not having to unplug when switching between the iron and tweezers.
Trying is the first step towards failure
Offline MaximRecoil
« Reply #13 on: December 04, 2016, 12:27:00 pm »
I don't get the point of tweezers like that. 2-contact SMDs (which is all that tweezers like that would be good for removing) can simply be swiped off the board with your normal tip (STTC-126 in my case). You put the tip to one of the joints, then move it to the other joint and sweep it off the board in one quick motion. Depending on your speed, and/or the amount of solder that's already on the joints, you may need to add some extra solder to the two joints first, which gives you more time to get your iron to the second joint while the first joint is still molten. I just made a quick video (with a crappy camera) to demonstrate this:
https://youtu.be/tfJw5hlWCiY
When I worked in a PCB factory in the late 1990s I did that all the time, and rarely had to add any solder to the joints first. This is the first time I've done it in about 18 years, so to be on the safe side, I added solder first (ensuring I didn't have to do multiple takes to get the hang of it again).
With regard to dual output on a Metcal, I've always wondered what would happen if you used an F splitter off one port like this:
Does anyone know?
« Last Edit: December 04, 2016, 12:44:38 pm by MaximRecoil »
Offline N2IXK
« Reply #14 on: December 04, 2016, 03:54:59 pm »
You would likely burn the splitter out.  They contain a tiny ferrite broadband transformer, that will not handle the several watts of power provided by the Metcal base unit.
"My favorite programming language is...SOLDER!"--Robert A. Pease
Offline Monkeh
« Reply #15 on: December 04, 2016, 04:02:22 pm »
Several tens of, you mean.
Offline MaximRecoil
« Reply #16 on: December 04, 2016, 04:46:59 pm »
Okay, suppose you didn't use one of those splitters, but rather, just a coaxial Y-cable, or an F connector "T" like this ...
... neither of which contain any components to burn out; they are just a 1-to-2 parallel connection.
« Last Edit: December 04, 2016, 04:49:58 pm by MaximRecoil »
Offline N2IXK
« Reply #17 on: December 05, 2016, 02:21:50 am »
You would then be loading the output of the RF power amp with ~1/2 the impedance it was designed for.  It may not like that, and magic smoke release becomes a possibility....
Offline jonatanrullman
« Reply #18 on: December 05, 2016, 11:25:52 am »
Also, it would kind of interfere with the regulating circuit of the base unit. If I haven't been completely mislead the station measures the amount of power returned by the handle and regulates the output to avoid frying it. Magic smoke sounds like a pretty good summary to me. :-)
I did however see a link a few days ago to a thread where someone had built their own supply for handles like the metcal. Perhaps you could build your own dual base unit instead?
CHeers
Offline wkb
« Reply #19 on: December 05, 2016, 09:16:29 pm »
CHeers
Well, no.  The heating element in the tip itself regulates temperature around the Curie point of the tip.  The generator has protection circuits for high SWR etc but it does not regulate temp.
« Reply #20 on: December 05, 2016, 09:24:12 pm »
I know that. But I was under the impression that to avoid getting say 50 watts of rf energy returned it monitored the return and regulated the output. That may or may not be the exact same thing that you mean by "high SWR etc".
Offline zapta
« Reply #21 on: December 06, 2016, 06:30:39 am »
Any idea how much power a handpiece consumes while resting in the stand? If this is a small fraction of the total 40W then the rest would be sufficient for a second working handpiece.
« Reply #22 on: December 06, 2016, 10:37:49 pm »
Since they don't have temperature regulation in the base unit I can only assume (since I don't have one myself) that the version that have a sleep mode shuts of the power completely to the handle, so the power consumption would supposedly be negligible. This would explain why some of the dual stations mentioned previously supported one handle in use at a time.
Would still have all other sorts of problems with hooking up two handles to a unit not designed for it though.
Cheers
Offline GreyWoolfe
  • NW0LF
« Reply #23 on: December 07, 2016, 01:02:34 pm »
scuse me , at soon i will buy an metcal soldering station "mx500".
I really wish see some pics of teardown before .
I also want to know if this unit will be good for me as i do not want to to use 2 channels at the same time ,but only 1 at time .
P.S :
i really can't find some metcal's mx500 or 5000 teardown pics ,can anyone help me ?
Thanks
It will work fine for you.  I have one and it is a real treat to solder with.  I wouldn't worry about tear down pics.  These are designed to work continuously in a production environment.  For the hobbyist user, it's basically bullet proof.
Offline SteveyG
« Reply #24 on: December 07, 2016, 01:36:51 pm »
Cheers
The base unit is always driving the iron. The magnet just interferes with the magnetic field around the heating element preventing it getting as hot.
No photos of the internals, but I wouldn't worry. If you can find an old MX-500 then even better as there is much less to go wrong. We have some 15 year old units at work still going strong.
