As GreyWoolfe said, there is a whole range. See what's popular on EBay (search for Metcal STTC).
I have:
* STTC-138 (1.5mm): General work, including SMD and through-hole.
* STTC-136 (2.5mm): Bigger. Good for through-hole (but the 138 works great for that too). Large gauge wires.
* STTC-117 (5mm): The big guy. Rarely used.
In between those, you'll also find:
* STTC-x25 (1mm): good for fine-tip SMD, maybe redundant with the x26 (conical hook)
* STTC-x37 (1.8mm): possibly the best size for through-hole.
So there is the whole range. The STTC-xxxP are the "stubby" ones (short). Even lower thermal mass. Honestly not sure why one would get these. Then they have some super-long ones.
A quick look on EBay for used STTC (probably representative of what people use on production lines) reveals that the most popular are:
136 (2.5mm chisel), 145 (conical), 126 (conical hook)
I have had good luck on EBay buying "seller refurbished" ones (check seller rating). The Metcal tips are indestructible, so, properly replated, they can last for a very long time.
