If you go into your user profile and set your country....
I did already, a few days ago. You on the other hand,...
I did receive the SP200 and I had a base board of a 3d cube laying around that I got sometime ago. I soldered a few sockets with the Weller and a few with the Metcal. They performed both equally well on the through hole components, I don't have any smd project around at the moment with which I could test the Metcal a bit more. It would seem that it has a bit more heat capacity (or a faster heater) than the Weller, I seemed to be able to go a bit faster from pin to pin.
The only thing I don't really like so far is that the on/off switch acts on the secondary side of the transformer. Who would put in a real switch and then not switch the incoming voltage... The transformer has a bit of a hum to it too, so you can hear it even if the station is off.
I will have to get some 2 mm chisel tip, which is my favorite with the Weller (TSSOP was no problem), the one on the Metcal now is quite a bit bigger. I have the SSC-636A, SSC-736A (both wide chisel) and a SSC-638A (pencil-point), so if anyone has any recommendations/favorites, I'd be grateful to hear about them.
I took a few photos of the driver box, see the attachments.
I'll try and keep this thread updated once I get my hands on an SMD board.
Pio
P.S. In the board, the upper row of DIP-sockets is soldered with the Weller, the lower with the Metcal
