I have the Brunel microscope. It's the one with the vertical head, and I'd rather have the angled head, but it came cheap off eBay, so beggars can't be choosers. I've made a base to replace the one that comes with it - it attaches to a baseboard with wing nuts so I can swap it to my watchmaker's lathe which sits on a baseboard with suitable holes. The vertical bar is much longer than the one that comes with the microscope - I found I was stacking it on top of books to get clearance sometimes.
I have x5 and x10 eyepieces, and x1, x2 and x3.5 objective lenses. I must say I find the optics excellent. I can work on it for hours at a time without strain. I use it for watchmaking, soldering, inspection, darning, picking brass swarf splinters out of my skin, you name it.
I can easily get watchmaker's screwdrivers under it, so a soldering iron (which is usually at an angle) is no problem.
HTH
John
