The above transistors have same case (TO-220), same wattage, and the same characteristics except the Vce which differs greatly - 120V, 150V and 250V.
So my question is how is the Vce determined? Is it a physical factor, ie the distance between two areas of the silicon, the greater the distance the higher the Vce? And if the physical characteristics must be different how come all the other attributes are the same?
Practically, which ones should I choose, if 120V is more than enough than what I need? Will the 120V do a better job than the 250V somehow, since I cannot detect any differences other than Vce? Or should I just use any of them interchangeably?
