Author Topic: morse-code ribbon cable (for lack of a better description)  (Read 659 times)
Offline free_electron
    • SiliconValleyGarage
« on: January 11, 2018, 07:34:14 am »
any idea where i can find this cable ( on 100m rolls. preferrably on ebay )
Offline elecman14
Re: morse-code ribbon cable (for lack of a better description)
« Reply #1 on: January 11, 2018, 08:04:47 am »
No luck on ebay. I looked for the product on Taobao and found out that it is referred to as UL2468 or 2468-26. Here is a source that you could order from: https://world.taobao.com/item/45414262362.htm. I have no experience with this seller (just picked a random one).
Offline tooki
« Reply #2 on: January 13, 2018, 10:09:08 am »
Out of curiosity, what's the purpose of the markings?
Offline Neomys Sapiens
« Reply #3 on: January 13, 2018, 03:03:06 pm »
For the colour blind?
« Reply #4 on: January 16, 2018, 07:14:00 am »
this is cheaper than colored ribbon cable and easier to make. the marking is just an ink squirter.
note that this cable is NOT 2.54mm pitch ! it is not for double row idc connectors but for those single line crimp connectors like JST PH XH and likes. It is a 2mm pitch.
this is used to make harnesses. you split off the wires one end can have  a 16 pin and a 4 pin and the other side a bunch of 3 pins , 4 pins or whatever. they are commonly used in TV and audiovisual equipment to interconnect circuit boards.
i want to use them in a 3d printer. i have a large 20 pin on one side and then a bunch of 2 3  4and 5 pins on the other end going to various elements.  the striping makes it easy to keep follow the wires...
The following users thanked this post: Koen
