Author Topic: My new toy :) Agilent DSOX2002A - Sex on a stick!  (Read 69194 times)
Offline Hydrawerk
Re: My new toy :) Agilent DSOX2002A - Sex on a stick!
« Reply #50 on: April 16, 2013, 08:03:28 pm »
I tried a special stereo wav file to display a pentagram in XY mode, hi-res and normal. The wav file was created by my friend. http://www.heckweb.ic.cz/
It also works with analog scopes...
« Last Edit: September 01, 2013, 09:17:17 pm by Hydrawerk »
Offline Hydrawerk
« Reply #51 on: April 16, 2013, 08:17:36 pm »
I installed a trial version of DSOX2EMBD. It will expire in May 2013. I wonder what happens if I keep on setting date March 2013.  :D :D
EDIT: I think that the trial will expire no matter what you do.  :-[
« Last Edit: April 18, 2013, 01:09:08 pm by Hydrawerk »
Offline Hydrawerk
« Reply #52 on: April 16, 2013, 08:19:32 pm »
Pictures of serial decoding. I am not very familiar with this feature yet.
Offline Hydrawerk
« Reply #53 on: April 18, 2013, 01:14:17 pm »
So I turned on the 30-day trial... It will expire in a month no matter what time you set.  :--
The DVM has a nice bar graph.
Offline Hydrawerk
« Reply #54 on: April 18, 2013, 01:17:16 pm »
The Search button is enabled but still very limited. Works only with serial decoding. The segmented memory looks good. But I know, you have much more segments at Rigol DS2000 :)
Offline Hydrawerk
« Reply #55 on: April 20, 2013, 02:31:56 pm »
When I turned the 30-day trial, the memory is now 500k points per channel when in Run/Stop mode and 1M points per channel in Single mode. It doesn't matter if you use one or two channels. Probably I will buy this optional licence in future. It looks useful.  :-+ Or some hacker should make a crack licence generator program.  :-/O
Offline Hydrawerk
« Reply #56 on: April 22, 2013, 01:10:06 pm »
When I received my brand new DSOX2002A, there was no protective plastic film on the scope's LCD... Isn't that strange?
But who cares...
Offline Hydrawerk
« Reply #57 on: April 22, 2013, 01:36:46 pm »
http://www.home.agilent.com/owc_discussions/thread.jspa?threadID=19202
Posted: Jul 21, 2011 12:26 PM
When I press WaveGen then Settings, pressing the second softkey from the right 4 times on my DSO-X2024, a window pops up showing the function generator parameters. Pressing the softkey 4 more time, the window closes. It's not mentioned in the User's Guide and I assume it only works when the WAVEGEN option is installed.
This doesn't work on my scope. Maybe because I have a new firmware with modulation feature.
Offline Hydrawerk
« Reply #58 on: April 23, 2013, 12:25:29 pm »
IR remote control
Offline Hydrawerk
« Reply #59 on: April 23, 2013, 12:27:14 pm »
Mask testing
« Last Edit: April 23, 2013, 12:28:47 pm by Hydrawerk »
Offline Hydrawerk
« Reply #60 on: April 23, 2013, 12:31:13 pm »
Noise
Offline Hydrawerk
« Reply #61 on: April 23, 2013, 12:36:04 pm »
The scope makes 2 000 000 000 samples/s, so it makes 2000 samples/us. When the trace is 250 us long, then it has 250×2000=500 000 samples. The record length is 0,5Mpoints in Run/Stop mode. In Single mode it is 1Mpoints.
Offline Hydrawerk
« Reply #62 on: April 26, 2013, 09:43:26 pm »
PSK modulation from WAVEGEN and deep memory. Unfortunately, the memory will expire in one month.  :(
Offline Hydrawerk
« Reply #63 on: April 27, 2013, 02:24:39 pm »
to Dave Jones
Maybe this thread should be moved to the Test Equipment section.
Offline Hydrawerk
« Reply #64 on: April 29, 2013, 06:01:31 pm »
Measuring the Trigger Output delay of the DSOX2002A. Here it is fed back into channel 2, and it appears the delay is about 42ns. It's better than Rigol DS2000, but I don't know whether this is an important parameter. Does someone know more?? I could not find anything on the web. The green DVM shows the Trig Out frequency.
« Last Edit: April 29, 2013, 06:04:33 pm by Hydrawerk »
Offline DRT
« Reply #65 on: April 29, 2013, 07:13:53 pm »
I tried this on my DSO-X3024A to see if the 3000 series has the same behaviour. I measured 34.2ns with a 9ns cable (1.8m of coax, VF=66%), so about 25ns overall. (You can see the reflection from the trigger pulse at about 18ns after the edge on Ch3).
« Last Edit: April 29, 2013, 07:18:40 pm by DRT »
Offline Hydrawerk
« Reply #66 on: May 08, 2013, 02:40:09 pm »
Here is the splash image that I found in the firmware CAB file.  :)
Offline Hydrawerk
« Reply #67 on: May 08, 2013, 08:17:29 pm »
There seems to be a bug in the Serial button led. It doesn't glow when I push the serial button and switch on the Serial decode function... But the LED is OK, it glows when I turn on the scope and all the leds are lit for a while.
On the other hand, I didn't find any bug that causes the scope to freeze or even crash. The firmware is well-done.
« Last Edit: May 08, 2013, 08:19:30 pm by Hydrawerk »
Offline Hydrawerk
« Reply #68 on: May 08, 2013, 08:20:53 pm »
Color variants of printscreens.
Offline Hydrawerk
« Reply #69 on: May 08, 2013, 09:06:17 pm »
I installed the IO Libraries Suite 16.3 and IntuiLink for 2000/3000 X-Series Oscilloscopes, Version 1.01
It works fine, but I will not use it very often probably.
Offline Hydrawerk
« Reply #70 on: May 08, 2013, 09:07:34 pm »
Microsoft Word plug-in.
« Last Edit: May 08, 2013, 09:09:19 pm by Hydrawerk »
Offline Hydrawerk
« Reply #71 on: May 08, 2013, 09:14:01 pm »
Microsoft Excel plug-in. In readme I saw this:
IntuiLink Toolbar for 3000 Series Oscilloscopes limits the size of data transfer to a maximum of 50,000 points regardless of the actual number of points on the screen. The 3000 Series can capture up to 8 million points (scope or logic channels) of memory. To transfer more than 50,000 points on the 2000/3000 Series scopes, use IntuiLink Data Capture for 3000 Series Oscilloscopes.
I will try it in future... http://www.home.agilent.com/agilent/software.jspx?ckey=896758&lc=eng&cc=CZ&nid=-11143.0.00&id=896758
« Last Edit: May 08, 2013, 09:19:46 pm by Hydrawerk »
Offline nukie
« Reply #72 on: May 09, 2013, 02:06:54 pm »
This forum is amazing, topic is about kibi's new DSO but first 5 pages or so discuss about IEC plugs, awesomely meticulous engineers here. :))
Offline Hydrawerk
« Reply #73 on: May 19, 2013, 03:28:09 pm »
Wieving angles of DSOX2002's screen. It's OK, but the GW Instek GDS-2000A is maybe better. Because they overload (?) the underlight LED's so they can give you only one year warranty on the display...  :palm: The rest of the scope has three year warranty.  :-\
https://plus.google.com/photos/106264218831814439783/albums/5857196858625060337
Offline Hydrawerk
« Reply #74 on: May 19, 2013, 10:25:31 pm »
This seems to be the way to evaluate bandwidth of my scope...
