The transformer inside the unit was bit heavy because of that ,the 4 screws that secured the transformer to the base enclosure been broken (courier transportation service didt give proper care to the product , that may be the reason). I tried my level best to put the screws back on by putting a small hole in the enclosure.
Regarding the PCB, i thing its the same PCB used on the Yihua 936, ill put more picture of the PCB very soon.
I think the circuit consist of one opamp, a triac and a Pot mainly... Original Hakko 936 contains 2 active IC's i think.
I checked the continuity between the solder pen tip with the mains AC earth lead, it was there and i am happy for that.
