Pace ADS200 reviewBuild quality. 9.5/10.The first impression you get when pulling it out of the box is "this station is damn solid". The station is all metal construction with an aluminum chassis, cast bezel and large rubber feet. On the front it sports a large red 3 digit display with a multi color iron status indicator to the right of it. The three rubber buttons that control the station are responsive with good tactile feedback and click. On the rear of the station there is an external fuse box, an earth/ground socket, and a socket to connect the optional Instant Setback Stand. The station chassis is star grounded internally for user safety.
The iron stand is also a hefty metal construction likely to cause blunt force trauma in the event of any bench disputes. It contains both a sponge and brass wool. The brass wool receptacle can be removed from the stand if required. The sponge has a tear out section in the middle to allow an edge for dross or small components to be caught off the tip of the iron. A nice quality heat resistant pad is provided to set tips down onto if required, otherwise the provided Tip Tool makes tip swapping fast and effortless. The optional Instant Setback Stand includes a cable to signal to the station that the iron has been returned.
The TD-200 iron which is the business end of the trio, is anodized aluminum with integrated molded rubber grip. The cable is heat resistant and has good flexibility. Cable strain relief is built into the rear of the iron by a rubber washer held captive with a plastic end cap. At the other end of the cable unscrewing the plug shroud shows an expensive and solid looking 4 pin din connector with locking plastic nut. Pace advises the cable (cord) is available as a spare in the very unlikely event of failure.
According to Pace the tips have a fairly thick iron plating to extend the tip life against harsh fluxes and lead free solder. They have been manufacturing this style of cartridge tip for quite some time with emphasis on long life and ruggedness.
Features. 10/10.This is Paces first station supporting their new Accudrive technology which gives the station close to single digit temperature accuracy and combines the features of a precision soldering iron with a high output iron delivering up to 120W. Because of this the station does not require calibrating, or entering offsets between changing tips. The station can be configured to operate between 177-454C (350-850F) and display units in either Fahrenheit or Celsius.
The station is of course ESD safe, which you would expect being a production quality station, with modern electronics these days almost essential for anyone trying to eliminate mysterious failures.
The three temperature presets accessed on the front panel can be adjusted to suit your preferences. You could do this based on your tip selection or use the settings to provide incremental boosts and increase available thermal power when required. To avoid inadvertently stressing fine tips or overheating joints, the station has configurable High and Low temperature limits. When going lower than the lowest temperature the station will enter Auto Off mode and power down the iron then you can use a preset or the temperature button to bring it back up.
All stations come the with ability to enter a low temperature standby mode called Setback. When the iron has been inactive long enough to trigger Setback, the station reduces the temperature of the iron. If the station detects the iron dropping further in temperature (i.e. touching the tip to the wet sponge or joint) the station assumes you are using it again and heats back up to the set temperature.
If you have the optional Instant Setback Stand you can additionally use the stand to trigger the station in and out of a Instant Setback mode which essentially is the same thing but controlled by the stand. There is also an Auto Off mode which when triggered will power down the iron fully. These are all separate timers that can be configured in the menu and designed to save power and prolong tip life. Setback or Auto Off modes can be interrupted by pressing a button.
There is a password lockout option to prevent other users messing with these settings.
Ease of use. 10/10.Very simple to operate, with 3 buttons on the front panel. The temperature preset selection button can be pressed in quick succession for the 3 programmable presets, the two up and down buttons (in 1 degree increments as of firmware 1.4) control temperature. The 3 digit LED display is visible from all angles and in high and low light. A single LED to the right of the display shows when the station is at maintained temperature or heating. The stations front face is angled slightly to allow natural viewing from both the bench or shelved.
The iron is extremely comfortable, easy to grip and cool to touch even with large Ultra Performance tips loaded. The tip to work distance is minimal. Tips can be hot swapped in and out of the iron in seconds with the tip tool. Tips heat up in just a few seconds and in most cases temperature changes are a couple of seconds. The stand is not fixed to the station and can be moved close to the work if required. It has storage for a handful of tips along with the tip tool.
Value for money. 10/10.The Pace ADS 200 goes for as little as $220 street price for the 120V model in the US, slightly cheaper if you can get a discount. Tips start from between $10 for Standard and $13 for Ultra Performance, significantly cheaper than other brand cartridge tips. Other countries may vary in price due to local taxes and importation costs.
Overall an absolute bargain for a 120W capable station. The station together with iron and stand, all top quality and designed for systematic day long abuse.
