Author Topic: New Raspberry Pi Model B+  (Read 22785 times)
Offline rolycatTopic starter
« on: July 17, 2014, 10:31:25 am »
In case anyone hasn't seen it yet, the Raspberry Pi foundation announced a new version of their single board computer this week:
It has loads of improvements including more USB ports, lower power consumption and more GPIO pins.
Still made in the UK and still $35.
Offline bwat
    • My website
Re: New Raspberry Pi Model B+
« Reply #1 on: July 17, 2014, 11:04:16 am »
Two of the most talked about products in this market are made(*) in Europe and both are quite affordable for those living in the countries of manufacture. I get the feeling that my perception of the economics of electronics manufacture doesn't quite match reality. I seem to believe that it just cannot be done unless it is manufactured in low cost countries. Obviously this isn't the case.
*)made/assembled/whatever.
"Who said that you should improve programming skills only at the workplace? Is the workplace even suitable for cultural improvement of any kind?" - Christophe Thibaut
"People who are really serious about software should make their own hardware." - Alan Kay
Offline bwat
    • My website
« Reply #2 on: July 17, 2014, 11:14:40 am »
I welcome the four mounting holes. I think I recall seeing it now uses microSD cards. I should confirm it but someone will correct me if necessary.
Try the link the OP gave.
Offline GeoffS
« Reply #3 on: July 17, 2014, 11:39:47 am »
+1 for four mounting holes.
No need for the hot glue gun any more :)
« Last Edit: July 17, 2014, 12:19:34 pm by GeoffS »
Offline firewalker
  • Country: gr
« Reply #4 on: July 17, 2014, 12:11:36 pm »
It will be nice a 1 Gbyte RAM version.
Alexander.
Offline AndyC_772
« Reply #5 on: July 17, 2014, 12:18:54 pm »
I wonder whether it'll end up like the BBC Micro model B+, from which it draws its name?
The B+ was supposed to be an improvement over the hugely popular Model B, but in practice the fact that it just wasn't quite the same as a Model B made it unpopular despite the technical improvements.
The software compatibility problems that came from its added memory and different floppy disc controller outweighed their usefulness, and it wasn't until the (much *more* different) Master series that these changes really became accepted by users are were properly supported by software. The poor old B+ never really got past the chicken-and-egg stage when it came to sales vs support.
Offline bwat
    • My website
« Reply #6 on: July 17, 2014, 12:23:26 pm »
I would take a beeb over a raspberry pi any day. Serious!
Offline rob77
  • Country: sk
« Reply #7 on: July 17, 2014, 01:32:58 pm »
Alexander.
it's still 512Meg. a colleague of mine has ordered it from Farnell and he's got it already. it's a nice board with a much better layout than the original B.
it has a microSD slot . the microSD card is "sticking out" approx  2mm from the board - therefore the microSD can be completely hidden and still accessible through a gap in the wall of the case if you'll have a case with wall thickness of 2-3mm.
in general it's well designed for embedding into products (compared to the original B).
Offline tszaboo
« Reply #8 on: July 17, 2014, 02:11:32 pm »
While it is an improvement, I still dont understand why the connectors are scattered on two sides, and why we didn't get back the I2S port.
Offline rob77
  • Country: sk
« Reply #9 on: July 17, 2014, 02:30:24 pm »
size is the limitation for 1 side ;) but anyways - 2 sides with connectors is acceptable - if you want to place it into a bigger case, then you just place it to the corner and make the cut-outs for the connectors on 2 sides of the case (that was not possible with the original B with connectors on all 4 sides).
Offline Precipice
« Reply #10 on: July 17, 2014, 02:59:35 pm »
If you're manufacturing something like this in volume, you don't need many people to run the line - it's mainly the cost of the machines, which is roughly the same globally, and some factory space, which isn't too bad, especially in Wales.
Inserting dozens of screws into a phone, lining up fiddly connectors, polishing shiny things - they all take huge amounts of effort, and go where the people are cheapest. Manufacturing operations that are un-green also tend to offshore to countries that worry less. SMT assembly is pretty green - energy in, packaging waste out, and there's decent recycling routes for most of that - although I don't know where the paper tape and cover tape from reels of passives ends up. Should burn well enough, I guess...
(UK manufacturing is still pretty healthy - it's less dominant than it used to be, because services have increased faster than it, rather than manufacturing declining, although headcount has fallen (continuously, I think?)).
Offline BloodyCactus
    • Kråketær
« Reply #11 on: July 17, 2014, 04:40:34 pm »
i know the B models had issues with usb throughput with just 2 connections.. sure lets add 4! ugh. gpio  is like a shotgun, pins all over the place. it would have been nice when going from 26 to 40 pin connector they re-arranged all the pins into a logical order.
very nice to see mounting holes!
-- Aussie living in the USA --
« Reply #12 on: July 17, 2014, 04:47:19 pm »
Lots of people want to attach a keyboard and a mouse, which are low-bandwidth peripherals, plus a wireless dongle and maybe from time to time a memory stick. Throughput shouldn't be much of an issue in the most common use cases.
But that would have made all of the existing plates and other peripherals incompatible, instead of just a few.
Always choices to be made, but I think they made the right ones.
Offline GeoffS
« Reply #13 on: July 17, 2014, 04:51:36 pm »
I run a couple of Model B's as weather cameras with a wifi dongle and a USB hard disk, makes trouble shooting a lot easier if you can plug a keyboard in.
Offline motocoder
  • Electrical Engineer
« Reply #14 on: July 18, 2014, 02:24:29 pm »
It looks like a nice incremental improvement, although I've sort of soured on the Raspi since that bad experience with their camera board and the rabid attacks I was subjected to for pointing out low light issues and suggesting USB webcams were a good alternative... Will stick with BeagleBone Black for the foreseeable future.
« Reply #15 on: July 18, 2014, 03:22:09 pm »
Not sure I understand this.
If by "rabid attacks" you mean this thread, then I would agree that 'jamesh' was inexcusably rude in his initial response to your post, but it seemed as though it was all resolved fairly amicably. A nasty response from one grumpy engineer doesn't seem like a good reason to abandon the platform altogether.
I don't frequent that forum however, so I may not have all the information. Were there other attacks?
Offline Richard Crowley
  • KJ7YLK
« Reply #16 on: July 18, 2014, 03:49:38 pm »
I also wasn't terribly impressed by the RasPi website or the forum.
The website has nice eye-candy and flash, but organization and presentation of hard facts, specs, and data is in short supply.
And the forum just leaves me cold. It seems unwelcoming to newbies and also disorganized.  They have a great deal to learn from Arduino.
The chaotic nature of the website and forum seem surprising to me given the number of boards out there.
But the new B+ module has most of the things I thought were sorely absent in the original board.
Offline amyk
« Reply #17 on: July 19, 2014, 01:17:07 am »
It's Broadcom, what'd you expect? Ask for more detailed information (e.g. GPIO rise times) and you'll be told in a very roundabout way, "no". (They'll try to play the "you don't need to know", "it's too complicated for you to know", etc. lines - these are people wanting to learn. :wtf:) Try asking harder and they'll just lock the thread. The forums are highly moderated to suppress any straying from the official line.
That camera thread is just... :palm: . He's basically advocating vendor lockdown. :rant: 'jamesh' is a total prick in many of his other posts on the forum too where people ask for more information.
All this, in a board designed for education, just disgusts me beyond belief and makes me think the whole thing is just marketing for Broadcom.
</rant>
Arduino is much better in that full documentation is available, you can use as much or as little of it as you want and won't be told otherwise. But the best computer for education is just a standard PC - tons of them are getting thrown away every day in fully working condition(!), many of them far more powerful than the Pi, and you can find far more information about programming PCs from low-level hardware and up, plus there's lots of software available. Even open-source BIOS replacements are available. Parallel ports (which are going to be common on old hardware, the type that's being discarded) make great GPIOs.
If you want a cheap ARM-based devboard, I'd say go for one of the Chinese SoCs - AllWinner make some pretty decent ones.
Offline motocoder
« Reply #18 on: July 19, 2014, 01:21:28 am »
There was quite a bit more than the one post in the forum from Jamesh, but quite frankly I have no desire to go back over there and revisit it.
The gist of it was, "you are hurting a charitable project by 'criticizing' one of its features". The whole thing was asinine, as my intentions were a) to point out the problem so they might fix it, and b) to point out that USB webcams work great with the Pi, so that others with similar requirements might be successful. I was as delicate and nice about it as humanly possible.
Jamesh, and to a lesser extent James, started out defensive, and then basically clammed up when I posted info showing the actual problem (including light meter readings, photos) and when others chimed in reporting the same issues. At no time did I detect any interest in following up with me or anyone to gather data to help determine the actual issue. Just a bunch of butthurt babies.
I wish them all the success in the world, but I'll send my business elsewhere. Plus, I really prefer TI products over Broadcom. I don't like that most of the data on the Broadcom part is not freely available.
Offline max-bit
« Reply #19 on: July 21, 2014, 05:43:17 am »
And they could add 1GB of RAM?
Offline rob77
  • Country: sk
« Reply #20 on: July 21, 2014, 08:44:05 am »
i think that would require a serious redesign - they're mounting chips one on a top of the other (CPU + RAM), so most probably a bigger RAM chip simply doesn't fit.
Offline Psi
« Reply #21 on: July 21, 2014, 08:56:49 am »
You mean i cant connect 4 ezcaps and save four uncompressed video streams  :'(
Offline bwat
    • My website
« Reply #22 on: July 21, 2014, 09:39:55 am »
Exactly! I've said similar things here myself -  https://www.eevblog.com/forum/beginners/advice-for-novice/msg468376/#msg468376. I apologise for hijacking the thread to boost a message I feel is quite important.
Offline rob77
  • Country: sk
« Reply #23 on: July 21, 2014, 10:37:14 am »
and how the hell would you teach interfacing hardware with a standard PC ? RPi is ideal - it runs a widely known OS, has GPIO and has high-level language libraries/bindings for the IO.
Offline bwat
    • My website
« Reply #24 on: July 21, 2014, 10:45:26 am »
I think this side discussion maybe needs a new thread.
