Author Topic: New Toy-YiHUA 853D+PLUS Rework Station.  (Read 24187 times)
Offline PeterGTopic starter
« on: October 21, 2011, 04:21:21 am »
Hi All,
    today I received my new YiHUA 853D+PLUS. I have taken a few photos for you all to see. It contains a Hot Air Rework tool, Soldering Iron and a basic Power Supply (0-15V at up to 2Amps). For those with limited space, this is an ideal tool.
The box contains:
The Main Unit.
A spare element for the Hot Air gun and the Soldering Iron.
6 Soldering Iron tips.
4 Hot Air nozzles.
Set of leads for the power supply.
I got mine from eBay auction: #220877083517 for anyone interested.
Now for the pics.
« Last Edit: October 21, 2011, 05:46:14 am by PeterG »
Testing one two three...
Offline shadewind
« Reply #1 on: October 21, 2011, 05:39:49 am »
Wow, that's a lot of different tools in one! Is it any good? :)
Re: New Toy-YiHUA 853D+PLUS Rework Station.
« Reply #2 on: October 21, 2011, 05:42:47 am »
I have just finished playing with it. Its Hot Air works very well, the Soldering Iron seems to work well but i have not done any serious work with it. I will do more testing on the power supply tomorrow , or maybe tonight.
Regards
« Reply #3 on: October 21, 2011, 05:47:14 am »
Fixed bad link.
« Reply #4 on: October 21, 2011, 10:31:40 am »
Just tested the Soldering iron. Not much you can say about soldering irons, but this one uses a Hakko element and tips. It seems to heat up very quick from room temp(a matter of seconds). This helps its rapid thermal recovery after each use.
The power supply volt meter seems to be approx 70mV from actual. Not too bad given the 100mV resolution of the display.
Regards
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #5 on: October 26, 2011, 03:02:28 pm »
It would be a more comparable measure to know if it heats to the proper temperature in terms of seconds.
The Hakko 936, and similarly the Fx888, will get to 350C in 40 sec or less.  The Metcal 5000 in 6 seconds.
To compare your new iron, you need to be able to measure the tip temperature with some accuracy.
If you have any eutectic solder around such as Sn99.3Cu0.7 which melts at 227C, the Hakko 936 reaches that temp in under 20 seconds.
Regards
Best Wishes,
 Saturation
« Reply #6 on: October 27, 2011, 03:19:06 am »
Saturation, I have tested the warm up time using 60/40 solder. It took the iron approx 25 seconds to melt the solder. I don't have a reliable way of measuring the tip temperature so this is the best I can do for now.
Regards
Offline saturation
    • NIST
« Reply #7 on: October 27, 2011, 11:23:25 am »
That's fairly decent, 60/40 melts at ~ 190C, 25 sec so it should reach 350C in under 50 sec [ estimating at 50 sec it will be at 380C, or 190x2 ]
Regards
Best Wishes,
 Saturation
Offline hacklordsniper
  • Country: hr
  • Don't turn it on, take it apart!
    • HackLordSniper
« Reply #8 on: October 27, 2011, 11:25:06 am »
Does this indicate the manufacturer is a open hearted and likes to give or the heaters are so bad they felt bad about not providing a spare  :) ?
Oh, the joy of sending various electronics to silicon heaven
« Reply #9 on: October 27, 2011, 11:47:17 am »
[/quote]
[/quote]
Time will tell..... :D
Offline necroscope
« Reply #10 on: October 13, 2012, 05:27:16 am »
Sorry to bump an old thread but i was hoping for a follow-up on this review as it looks like a great station,
Just wondering what your thoughts are on the Yihua 853D+  Since it has been some time since you purchased it,Is it still going strong?Is it good value for the price?Thanks.
« Reply #11 on: October 13, 2012, 09:08:41 am »
I can honestly say i have gad no issues at all with this unit.
Regards
