My experience so far with crimpers is: if you get a deal, buy the original tool. If you are "just a hobbist" and don't care about the crimp quiality and want the thing crimped, I urge you to get the engegneer PA series, however there will be drawbacks, like you won't get a perfect crimp mechanically and so, it might be an issue later when the stuff is under stress conditions and it's a dobule crimp mechanism, moreover they can't hold the connector during the crimping operation.
If you are looking for crimping JSTs you might consider a D-sub crimper. There are slight variations in desing between manufacturers however take something that "follow the design", and you will get a fair crimp. Pefection = $$$ (a lot!). Also search for a crimper that will hold the connector while crimping... For extremely fine stuff like 30 AWG or more, you require special equipment, otherwise it won't crimp at all or you will damage the contact inevitabley, but prices will be as high as the stars:
https://www.distrelec.it/it/pinza-crimpare-senza-inserto-daniels-dmc-m22520-01/p/18061814?queryFromSuggest=true This for example is used to crimp up to 32AWG and it also check the correct lenght in the crimp (for circular turned type contacts), and yep, it's 500 Eur before tax.
The real issue with crimpers is that you have to buy decent stuff straightfoward or you will be buying them forever and you will end up with wasting lot of money... Also, needless to say, but if you use a particular type of connecor a lot, you need the whole set, because something as simple as uninsulated faston sockets or sleeves in reality have a wide range of variations that can preclude you from peforming the crimp correctly. As for the 1mm jst or molex a D-sub capable crimping piler will do the job. Weidmuller sell those for 300 Eur, however you might be lucky to find them used on ebay.
Also, one other thing: for original Dupont connectors those are extremely rare connectors and it's unlikely you have those. The chances are that you have the cheap-chinese ones for breadboard stuff (probably off ebay), and D-sub works...
Crimping equipment, is something anyone involeved in elecronics should have, and it's often a very superficially-looked section!
