To boil this down you are looking for:
-High end consumer - lower end "prosumer"
-Records to SD cards
-No need for professional and high bit rate codecs
-No need for XLR inputs (some models come with them anyway)
-Compact in size
In case I missed it - Do you have a brand preference and or brands to avoid and a rough budget range?
No, not really.
But it ain't that easy. Small things make a
huge difference that can make or break a decision.
For instance the shitty toy consumer audio level bargraph on the Sony units instantly rules them out. I live by my proper dB level meter in the Canon.
Ability to mix internal and external audio my Canon is a big deal.
WiFi remote control and clip playback would be very nice.
The LCD screen must be big and high res. My canon is 920K pixels and I won't want anything less.
Battery life is important. The Panasonics for example suck at this, double the consumption of other brands.
I would like (and currently do not have) an easy way to play back video clips after I have shot them, without having to go into playback mode and back again. The Canon I have (and the new ones) suck at this, they can only play the last 4 seconds, without audio!
Dual SD cards and backup recording modes would be nice.
Assignable buttons for things like the auto exposure mode, and a control wheel to set value, if I have to go into a menu to do this then my productivity drops massively. Can't imagine living without that.
Must work with a suitable macro lens attachment. This might be impossible to know unless you actually test it.
Must be at least 30mm wide angle, preferably better.
And probably other things I can't think of at 1am in the morning...
