1) Is it possible, with the current available equipment and without significant DIY (like soldering), to use two passive power supplies in a personal computer — without there being serious drawbacks? Don't worry about cost, unless we're talking about one of those super-expensive linear supplies marketed for pro audio.
2) Is it possible to avoid any potential cross-contamination issues (problems related to chaining two power supplies together) by forcing a graphics card to draw all of its power from PCIe power connectors (none from the slot), in order to use one power supply just for powering graphics cards? If it's not possible, why isn't this something the industry has thought of?
3) Will someone here make either a double-sized passive switching PSU for computer use (given that a single ATX passive PSU can be found in up to 520 watts), so enthusiasts can get 750-850 watts out of a passive model — along with a compatible case?
This device,
AddPSU, has good ratings on Amazon.
Please don't tell me to just get a PSU with a fan on it. They all make too much noise when they're loaded enough. The closest thing to a quiet one is the Corsair RM 850 and it has questionable caps and cooling. It seems to me that the best way to enable a passive (or a PSU with an extremely slow-moving fan) high wattage power supply is to either use two of the fanless units or have a double-wide unit. Without so much surface area than ATX provides I don't see how it can be possible to extract more watts out of a passive or nearly passive unit.
A person with a bad attitude responded with this. I am wondering if there is more to it than what he wrote which is why I'm asking here:
It's a really bad idea. There have been attempts before on other parts of the Internet to run 2 PSUs and it is an extremely bad idea. As has been pointed out, you need both PSUs to start up together. What then happens if one PSU goes off and the other carries on supplying power? Or if one PSU has an earth fault and the other doesn't and a shock takes the path of least resistance to earth... through all of your components.
Efficiency is worse than with a single larger sized PSU. Conversion is always more efficient on a larger scale so doubling up a smaller sized PSU will waste more electricity, giving more heat.
Now that you bring up electrical noise... you do know that with those two PSUs you're going to have a separate ripple voltage on each along with all of the other kinds of power distortions. You're ruining your power quality by having 2 PSUs and a dirty common GND between them (earth looped of course) even if things do work correctly (that gadget you linked to only gets over startup issues, nothing else). Worse power quality means worse overclocking potential.
A single decent fan cooled PSU can't possibly be as loud as all of the other components you're going to have. Why bother having something quieter when it will be drowned out anyway?
Can someone kindly explain to me if it's truly unwise to use two passive power supplies, and why. Also, if it were possible (assuming it isn't) to power just graphics cards with one power supply, would that eliminate the main problems — since they're caused by connecting two power supplies together? Thanks!
