I had a lot of problems, actually total fail, trying to solder a new display connector onto a Macbook Pro main board. I also had to replace a resistor, really hard. The ground plane on these boards suck all the heat away. I've tried with all manners of tips for the Ersa iCon i-Tool, which in itself should be powerful enough under other circumstances. I did get the old display connector removed using an Atten 858D+.
So I got me a Puhui T-8280 from the UK at around 110 pounds total (currency, not weight). The advantage, except for the price, is the size. It can easily heat an entire Macbook Pro logic board.
The manual says to set it to 100-120 C for Pb/Sn solder, 120-140 for unleaded. The thermometer on the device is touching the heating plate from above. With this arrangement, setting the T8280 to 120 C, the top of a test board barely reached 50 C, so I bent up the thermometer holder a bit until the tip of the thermometer rested a mm or so above the plate (see image). That improved things somewhat. However, the top of the board never gets much above 68 C, and the bottom of the board reaches around 85 C after about 15 minutes on the 120 C setting.
When setting the device to 150 C, the top of the board reaches around 88 C after 15-20 minutes, the bottom gets to 105-107 in the same interval.
I've attached the graphs of these two experiments, each including 20 minutes of active heating, and another 20 minutes of the device cooling off with the small switch set to off and the mains switch still on. (In the first graph, I didn't measure the bottom temp from the start.)
My question now is this: the manual says to set the T8280 to 140 C for leadfree PCBs, but that results in a board at effectively 90-105 C. For effective soldering, shouldn't the board itself, at least the bottom of it, reach 140 C? Which would presumably mean that I should set the T8280 to 200 C or more to get to that level. I'd appreciate some opinions about this before I set out on a quest to set logic boards on fire.
And, incidentally, now I see the point of preheaters having a temperature probe you can attach to the board. Ersa does that, I think. OTOH, their preheaters cost 1-3k euro... Maybe I should move the fixed probe on the T8280 and make it attach to the board? Anyone done that here?
BTW, they included a long and narrow sticker made of foil, see the last image. I can find no explanation what it's for. Does anyone know?
