Hi! Since I work as a medical examiner, I have tried a lot of types of cotton swabs in my work. So I am, to some extent, an expert on this issue, lol. To clean printed circuit boards in your place, I would try foam swabs or other cotton swabs from this site. I usually buy such consumables because they have high-quality goods at low prices. As a bonus, with such a cotton swab, you can do an express test for covid, which is very relevant now, lol. But seriously, look for what you need on this site. They have great products at low prices.
Well that sure is interesting. I never knew about the wild world of swabs
I use moleskin or bamboo cotton ones.
Don't underestimate stiff brushes either (take a pointy nylon brush and cut it short to like 2mm) for agitation of substrate prior to swab pickup. When the bristles are very short you can kind of 'scale'/scrape things like dried up flux thats in a small puddle of alcohol so there is less rubbing required for pickup, then clean the brush by wiping it on a dampened rag. Causing the contamination to 'fracture' makes cleanup alot easier.
Can you tell us about various swab types? The website has a whole slew of stuff.
For instance, what is foam covered cotton for? Does the cotton work to absorb liquids better ?
Whats microdenier? Whats the difference between knitted and non knitted?
A 'choice for use' table/catalog would be nice.
And can you tell me about what swabs are good for alcohol, I like the micro-q-tips from Caig but once you dip em in alcohol or deoxit it seems pretty easy for the cotton to come off the stick when you are scrubbing.
