Hi all,
I'm looking out for a new desk lamp, and would appreciate any recommendations and UK suppliers.
I want something which is adjustable, with a fixed base and a head which I can raise up to provide general illumination of my bench, or bring down lower for inspection and soldering. The brighter, the better.
Right now I have an 'angle poise' type unit into which I've fitted a CCFL bulb. The two weren't really designed to work together, so the spread of light is poor, and the electrical noise from the bulb is a big problem. I do a lot of work on sensors and instrumentation, which can be highly sensitive to kHz and low MHz band noise. I can always switch the lamp off when probing something sensitive, but that rather defeats the object.
Any suggestions welcome, thanks.
