Thanks for the responses!
Hi!
Only one question: With the Eurocircuits Reflow Mate, how many of the recommended JEDEC curves can you achieve?
Just download eC-reflow-pilot and test by yourself.
JEDEC curves:
http://www.jedec.org/sites/default/files/docs/jstd020d-01.pdf
http://ww1.microchip.com/downloads/en/AppNotes/00233D.pdf]
eC-reflow-pilot:
http://be.eurocircuits.com/shop/offtheshelf/product.aspx?ano=ec-reflow-pilot&ad=8743
Good idea. I did that and according to their software, they support the full 3°C/sec heat-up. Cooling seems a lot less controlled, the predefined profiles appartenly just ask you to open the door to cool off at about those 6°C per second. I'm not sure what to think of that. Also, I'm not sure if the device will actually match these specs, and match them evenly over the entire board area...
I would call them and ask which reflow oven do they rebrand. It is quite obvious that they dont make it themselves, maybe they just added some ideas (like the eC compatibility) and look for the OEMs review.
Or visit them on Electronika 2014 I'm sure they bring one there.
Yeah I'll be there(I work in Munich, so I'm there every year anyway) but I'd like to get a review from somebody not working for their sales department
Bear in mind that anything "production grade" will be designed for continuous usem and may have signifiicant warmup time and power requirement (e.g. 3-phase)
For prototyping use, a simple toaster oven is fine. Spend the rest of the budget on a Mantis scope, a decent stencil printer, vacuum pickup, paste dispenser and a few other toys.
If it is for work, I dont see how the hacked toaster ovens even enter the competition. I mean you need something which works out of the box, and you can put in the working area and use without anyone lathing at you. Also, you are pretty much spending someone else's money, and you dont decide that you would rather like some other tools because you saved money.
Yeah, toaster ovens are out of the question.
We have professional hand-soldering tools here, we do EASA-certified avionics hardware rework. But these guys are over their heads in work and can't do assembly for our prototypes and they don't have equipment for BGAs at all.
hmmm nice thread. i will be interested to know more about reflow ovens. the 2nd post about JEDEC curves ... are they absolutely critical? if say an oven is partly malfunction, how can it tell you it is NOT following a curve correctly? i dont suppose it has a post flow job print out of the curve? but by then, the process is already done and the batch is subject to a wrong curve ... (apologies if i ask too many things, and i can understand how some sensitive component cannot sustain too fast a temp change)
Actually, it has a post-flow print out, including a print from an external sensor you can put right on the board.
Ho ho ho. There's at least as much tuning involved in a linear oven as there is in a toaster oven, but there's a massive warmup time too.
They're great when you're doing a big production run and can tweak the process over a few boards, but it's far from fire & forget. (For that, vapour phase seems to be the way, and they're not crazy-expensive unless you want an in-line one).
As it happens, I've got the same batch oven as rx8pilot (well, its predecessor). It's not bad at all, and makes good boards - but I _know_ I'm stepping outside profiles sometimes, getting the slowest bits of the boards up to temperature pushes the fast bits too hot. No harm is done (it seems), but I'm not completely happy, especially on big panels of boards.
At least the big window lets me watch (and worry!), and thermocouples taped to the PCB give me some reasonably truthful numbers (the oven measures air temperature...)
Homebuilt vapour phase lurches ever closer. Next break I get (probably new year), I'll be attaching this here pile of Melexis 16x4 IR sensors to my PID controller, to see if I can deliver an acceptable ramp profile.
THAT's the answer I wanted to get most(well, I don't like it but that's the info I needed), sorry if the question didn't lead up to that enough.
So vapour phase sounds like the best thing after all... but these are somewhat expensive... the same vendor offering the SMT 200C offered a used vapour phase system for 8000$...perhaps I should convince management to spend a little more.
