Author Topic: [REVIEW] Rigol DG4062 function Generator  (Read 35019 times)
Offline chromeTopic starter
« on: June 01, 2012, 11:38:12 am »
The box comes with:
  • the device itself
  • Power Cable
  • BNC cable (1Meter)
  • USB cable (1.5Meter)
  • CD with software and pdf files
  • Warranty paper (mine is in chinese)
  • Calibration Paper (doesn't list any numbers just says all is fine)
  • Quickstart manual (Chinese and English)
What I don't like about the device:
  • The Fan is pretty loud (a lot louder than the DS1052E).
  • The keys seem to not respond all that great, you really have to press those keys (you can see that in the video).
  • The pop-ups stay too long in my opinion.
I'm not sure about the following:
  • The power led fades on and off when the device is not on, its very very dim but I bet it could annoy some people (not me though, I sleep in the same room and I haven't noticed a thing).
  • For some people the 16kpts arb length might be not enough.
  • The square wave at 25MHz doesn't really look like a square wave at all but I don't know if that's a problem or not, I doubt it is.
Things I like about the device:
  • Dual channel, both channels can do the same thing, no channel that's lesser then the other like some devices.
  • The amplitude settings, you can do either Amplitude and offset or High point and Low Point.
  • The output impedance, either High-Z or 1-10.000 Ohm.
  • I think the boot time is pretty quick.
  • Large clear screen.
  • The Help button could come in handy.
  • Counter works really well, i do wonder if the 10MHz input would also be used for that.
Bugs found so far:
  • Under "Utility" > "CH Copy" the "Type" is misspelled as "Tpye".
  • When the 2 channels are coupled, (CH1 being the Base channel) with CH2 having a phasedeviation of 90°, whenever you change the frequency it loses this phase deviation (the number still says 90° but the actual deviation is only 0°), Pressing "Align Phase" doesn't do anything, the only way to fix it is to change the phase deviation on CH1 and then back to 0° and then it works like it should.
  • This is not so much a bug but it would make the device a lot more usable; when you use the knob to change the value of something and for example the value is 5.000 and you are standing on the 5 with your cursor you can turn all the way down to 1.000 but then it stops, it would be nice if when you stood on the 1 and turned even lower it would jump over to the next digit so you could scroll even further for example you would go from 1.000 to 900 and then 800 etc.
DC values, Set vs. Measured
Set DCMeasured DC
0.001VDC0.0009909VDC
0.01VDC0.0099923VDC
0.1VDC0.1001393VDC
1VDC1.000954VDC
10VDC10.03383VDC
-10VDC-9.998436VDC
AC values, Set vs. Measured
Set ACMeasured AC
1VAC0.99734VAC
5VAC4.99469VAC
7.0721VAC7.06745VAC
5VAC values Measured over Frequency
5Hz4.99866VAC
10Hz4.99462VAC
50Hz4.99527VAC
100Hz4.99433VAC
10kHz4.99088VAC
100kHz4.98513VAC
1MHz4.96144VAC
« Last Edit: June 04, 2012, 10:57:34 am by chrome »
Re: Rigol DG4062 function Generator
« Reply #1 on: June 02, 2012, 10:46:35 pm »
If there is anything you want to see/know then tell me and I'll either make video or just tell/show you (mind you I don't have a spectrum analyzer only a scope and a 6.5Digit DMM).
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #2 on: June 03, 2012, 10:08:44 pm »
How responsive is the knob for adjusting frequency? - is it smooth or does it jump or glitch?
Day Job: Mostly LEDs
Re: [REVIEW] Rigol DG4062 function Generator
« Reply #3 on: June 03, 2012, 10:21:29 pm »
Looking at the specs, seems like the only difference between the 60,100 and 60M models is tha output bandwidth  - the sample rate is the same (not sure how useful a 160MHz waveform will be at only 500MSPS sample rate).
- I wonder if this is another varicap slugging job... hack time I think..!
Offline nctnico
« Reply #4 on: June 03, 2012, 11:06:05 pm »
For 160MHz a samplerate of 320MHz would do in theory. In reality you will need a little bit more but not 500MHz. Don't forget bandwidths are always specified for sine waves.
Offline rbola35618
« Reply #5 on: June 04, 2012, 01:31:43 am »
Mikeelectricstuff
From what I remember, the knob was smooth and has better feel than the DG1022 series
RBolanos
Offline typeglob
« Reply #6 on: June 04, 2012, 02:11:52 am »
Analog Devices in their document on DDS use a ratio of 40% for the output frequency vs the clock frequency; that would come down to 400 MHz to generate that 160 MHz signal.
« Reply #7 on: June 04, 2012, 08:55:22 am »
It sort of depends, if you turn it normally then it's smooth, if you try and turn it at really fast speeds then it only updates it when it's stable(the number on the screen).
I bet there is but I don't know enough of this to try it, I bet they figured out a way to stop the DS1052E drama by only changing the serial though.
« Reply #8 on: June 04, 2012, 09:17:53 am »
Exactly - "In Theory" = assuming a perfect output filter, and the whole point of an AWG is it can generate more than just sinewaves - calling it a 160MHz AWG with only 500MHz sample rate is s bit cheeky.
With  a fixed 500Msps, I can't see that the additional $500 premium of the "160MHz"  would be value for money in terms of extra capability.
..and BTW - major Rigol website FAIL - have to register to get datasheets, user guides etc.!
 Fortunately some of the distributors have more accessible copies.
« Reply #9 on: June 04, 2012, 09:27:29 am »
I have all the copies you might want, do you want me to send them?
  • Datasheet
  • Programming Guide
  • Quick Guide
  • User Manual
« Reply #10 on: June 04, 2012, 09:40:21 am »
So I did a test, I set up a sweeping signal from 1 to 50MHz.
You see the amplitude drop the higher the frequency gets, I don't know if this the scopes doing or the waveform generator itself, using a 50Ohm terminator doesn't help.
Also this is a square wave at 25MHz:
The scope is not modified, it's running firmware 00.02.01 SP1   @  50MHz
« Reply #11 on: June 04, 2012, 11:27:55 am »
So it is my scope then?
Offline Akaminario
« Reply #12 on: June 04, 2012, 12:11:22 pm »
well it's better to see the harmonic distortion and phase noise of the sine wave~~
any more pics to show more details about the inside of DG4062 ??? THNAKS!
« Reply #13 on: June 04, 2012, 12:17:06 pm »
There was no bandwidth limitation on so it might be ok.
I'm not gonna open the device, i would prefer to keep the 3 Year warranty by not voiding the warranty, but PeDre has opened the device so you can see that in his post.
I wouldn't know how to check for the harmonic distortion and phase noise of the sine wave, remember I only have a scope.
Is this what you want?
« Last Edit: June 04, 2012, 12:39:05 pm by chrome »
Offline Rufus
« Reply #14 on: June 04, 2012, 12:39:39 pm »
Sine is the only thing it does at 160MHz. ARB is limited to 40MHz. At 160MHz the output is limited to 1vpp into 50 ohms. At a given frequency the maximum output level is the same across models. I wouldn't be surprised if there is no hardware difference at all between models.
You can submit any old garbage and carry on with the download. I have done that on every visit you would think they might get a clue from the amount of garbage submitted.
Offline Akaminario
« Reply #15 on: June 04, 2012, 01:57:10 pm »
Hello,
this are the best pictures I have.
Peter
Thanks ,good pics !
« Reply #16 on: June 04, 2012, 04:55:20 pm »
Offline Akaminario
« Reply #17 on: June 05, 2012, 01:12:20 am »
Hello ,i saw the harmonic distortion,thanks !
it looks the Harmonic Distortion and Spur is not the same as the datasheet ~
i read the datasheet,it told me :
Harmonic Distortion  Typical (0dBm)
                                 DC-1MHz:                <-60dBc
                                 1MHz-10MHz?           <-55dBc
                                 10MHz-100MHz?      <-50dBc
                                 100MHz-160MHz?     <-40dBc
WELL but ur output amplitude  is 5Vpp~~~~ would u pls show me the 0dbm's performance?
meanwhile  i think is't not suitable to test a 14bit Vertical resolution generator's performance
by using a oscilloscope(8 bit ADC), because i'm not sure the distortion result u show above is
made by the generator itself or by the AFE of the oscilloscope~ !
Thanks!
« Last Edit: June 05, 2012, 01:22:43 am by Minya.Konka »
« Reply #18 on: June 05, 2012, 09:47:01 am »
And how would I do that?
Offline eSaloooo
« Reply #19 on: June 06, 2012, 03:38:29 am »
Hi all
i got Rigol DG4102 and DSA-815 ;
i tested the sine wave  of DG4102 , i found the result is pretty good as the specification ,the
harmonic distortion is good enough for my daily applications ~
hope its helpful for u guys , thanks ~~~
« Reply #20 on: June 06, 2012, 05:49:11 pm »
The fastest I could get the device to rise/fall: (ignore the rigol counter, it was 15MHz according to my Philips PM6615 Counter.
Offline nctnico
« Reply #21 on: June 06, 2012, 06:04:08 pm »
A lot of people forget signals are basically a bunch of sine waves mixed together.  Bandwidth indicates the limit for the highest sine wave component an AWG can produce. Whether that is usefull or not is up to the user.
Offline stupid
« Reply #23 on: June 30, 2012, 03:11:32 pm »
In DG4062 spec,rise time for square is less 12ns(1Vpp),but for arbitrary is less 5ns, and not definite rise time for pulse?I think if you use higher bandwidth scope like 1GHz above to measure,you should get the precise value.
When I using TDS1012 to measure sync of 33120A,the fall time is around 3.5ns, but when using SDA760Zi, it changed to 700ps.
« Last Edit: June 30, 2012, 03:13:39 pm by stupid »
