Sorry mrpackethead, I meant December 31st.
Anyway, the machine arrived much earlier than I expected, and I'm unpacking the machine now. Everything was carefully packed in a sturdy wooden box. Attached are some pictures. The machine is currently sitting on the shipping crate (obviously turned upside-down). If you get a 2800-size machine, definitely have some other people help you move it. I had three other people help me lift it out of the crate.
Hardware: I wasn't sure what kind of airline the machine would have, and I'm pleased that it comes with a 1/4" NPT male connector, so I can easily hook it to my air compressor without additional fittings. I need to order an oil/water/air separator, but I'm waiting to hear back from Michael about what filter size (5um, 40um, etc) he recommends.
Software: At the end of installation, there is an option to automatically install the usb driver and visual c++ runtime environment. The automatic installation didn't work because of Windows permissions (I got some errors alluding to an inability to install C:\SMT\supportfiles\vcredist_x86.exe and C:\SMT\supportfiles\usb_serial_driver\SETUP.exe), but this was very easily fixed: I re-executed both executables myself and clicked through the Windows dialog.
My next step is to order a 1:2 stepup transformer, since it looks like the machine is not working properly with 120VAC. The website says that these machines work with 110/230VAC, but Michael just told me that they actually work only with 230VAC. I'm waiting to hear back from him about peak power consumption before I buy a transformer. I'll post more after that. I hope someone finds this helpful!
Update: Michael from SmallSMT says that a 40um filter on the air line is fine, so I ordered Airtac GFR: Filter/Regulator with Metal Bowl - GFR300C08AC3T (I've heard bad things about plastic and glass bowl filters, and this one has an automatic water drain). Michael also says "Your main switching power supply is able to deliver 480W but used maybe 200W. The X motor has 200W, Y Motor 400W. So maximum peak power consumption can be 700VA if you run the machine on high speed." It looks to me like this actually comes out to 800W, but I got a 750W AcuPwr step-up transformer (ACUPWR AU-750), which is tested to 900W continuous. I expect to get these parts late next week -- more updates then!
Update 2/20/17: Transformer is here, still waiting for air filter. Machine powers up nicely. You should avoid GFI outlets: Big inductive draw-down when machine powers on will trip GFI, but standard breaker is fine. Haven't programmed a board yet, but I've moved X, Y, heads 1 & 2 (Z and theta), West tape advancer, and switched through the 3 cameras. Have not loaded any tapes yet. Learning: I thought "VideoNo1" and "VideoNo2" would cycle between the cameras, but learned that you should always use "VideoNo1", as "VideoNo2" crashes the program. Within "VideoNo1" you can choose to look at any of the 3 cameras ("Mark Cam", "Bot. Cam1", "Bot. Cam2"). Will post a video soon!
